[Qgis-user] Error message: Processing toolbox
Etienne Trimaille
etienne.trimaille at gmail.com
Sat Sep 30 23:41:43 PDT 2017
You should avoid cross-posting on many mailing lists. (qgis-user and
qgis-dev)
2017-10-01 0:08 GMT+07:00 Pat Hin <phi73 at gmx.de>:
> What can i do before fully reinstall what i would dont like due to lose
> all my projects etc.
You should update your version of QGIS 2.18, this bug has already been
fixed. You won't lose your projects.
Etienne
> thanks
> pat
> Konnte Erweiterung processing nicht laden aufgrund eines Fehlers beim
> Aufruf der classFactory() Methode
> TypeError: coercing to Unicode: need string or buffer, NoneType found
> Traceback (most recent call last):
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 333, in startPlugin
> plugins[packageName] = package.classFactory(iface)
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py", line 38, in classFactory
> return ProcessingPlugin(iface)
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/ProcessingPlugin.py", line 58, in __init__
> Processing.initialize()
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 148, in initialize
> Processing.addProvider(c())
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 103, in addProvider
> % (provider.getDescription(), traceback.format_exc()))
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/algs/saga/SagaAlgorithmProvider.py", line 123, in getDescription
> version = SagaUtils.getSagaInstalledVersion()
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/algs/saga/SagaUtils.py", line 130, in getSagaInstalledVersion
> commands = [os.path.join(sagaPath(), "saga_cmd -v")]
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/algs/saga/SagaUtils.py", line 75, in sagaPath
> if not os.path.isdir(folder):
> File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/genericpath.py", line 49, in isdir
> st = os.stat(s)
> Python-Version: 2.7.10 (default, Feb 7 2017, 00:08:15) [GCC 4.2.1
> Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
> QGIS-Version: 2.18.2 Las Palmas, exported
> Python-Pfad:
> - /Applications/QGIS.app/Contents/MacOS/../Resources/
> - /Applications/QGIS.app/Contents/MacOS/../Resources/python
> - /Users/hindenberger/.qgis2/python
> - /Users/hindenberger/.qgis2/python/plugins
> - /Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins
> - /Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7
> - /Library/Frameworks/GEOS.framework/Versions/3/Python/2.
> 7/site-packages
> - /Library/Python/2.7/site-packages/numpy-override
> - /Library/Python/2.7/site-packages/matplotlib-override
> - /Library/Frameworks/GDAL.framework/Versions/2.1/Python/
> 2.7/site-packages
> - /System/Library/Frameworks/Python.framework/Versions/2.7/
> lib/python27.zip
> lib/python2.7
> lib/python2.7/plat-darwin
> lib/python2.7/plat-mac
> lib/python2.7/plat-mac/lib-scriptpackages
> lib/python2.7/lib-tk
> lib/python2.7/lib-old
> lib/python2.7/lib-dynload
> Extras/lib/python
> Extras/lib/python/PyObjC
> - /Users/hindenberger/.qgis2//python
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171001/1d77a0c1/attachment.html>
