[Qgis-user] Fwd: QGIS web map - add author name
Yossi Rokni
yossi.rokni at gmail.com
Thu Aug 2 03:32:41 PDT 2018
Thanks Phil,
This really helped and solved the problem.
However I have some issues:
I worked according to your instructions and updated the index.html file -
It solved the problem.
But when I publish again the web map, I get a new index.html file without
this manual update.
I looked to the link you sent me in github. They discuss there doing this
kind of manual update in the template. So I went to the templates files
in C:\Users\username\.qgis2\qgis2web\templates folder and made this manual
update in the template files.
This solves the problem when I re-publish the map.
But it doesn't solve the problem when I make an update in the map and save
it in QGIS Desktop.
I guess a solution for this requires an enhancement in QGIS Desktop.
Per your advice I opened a new enhancement request on github.
Thanks again
Yossi
בתאריך יום ה׳, 2 באוג׳ 2018 ב-11:19 מאת Philip Barlow <
philipb at pembrokeshirecoast.org.uk>:
> Hi Yossi,
> You could just add something like this to the index.html output at the
> bottom between </script> and the </body>?
> </div>
> <div style="position: fixed; left: 100px;
> top: 20px; background-color: white; opacity:0.6; padding:0px;z-index:2;">
> <h1>Your title</h1>
> </div>
> The z-index is important, make sure you add it to the div id for the map
> or else your title will be underneath your map and you won’t see it.
> Like this:
> <div id="map" style=*"z-index:1;">*
> You’ll find some more info here:
> https://github.com/tomchadwin/qgis2web/issues/415
> You could put in an enhancement request on github?
> Hope this helps.
> Phil
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Yossi Rokni
> *Sent:* 02 August 2018 06:57
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Fwd: QGIS web map - add author name
> I created my first web map in QGIS, using the good instructions in this
> web page:
> https://www.qgistutorials.com/en/docs/web_mapping_with_qgis2web.html
> I want to add a fixed text
> (such as author's name)
> at the bottom of the map.
> Is it possible to do it by updating the file qgis2web.js or any other way?
> I am not familiar with java script - it would be great if you could
> provide me
> an example of
> the relevant java script command that I need to add into qgis2web.js.
> Some more details:
> I use QGIS version 2.18 (I tried using QGIS 3.0, but I couldn't create a
> web map in this version).
> I created the web map using qgis2web plugin.
> Thanks
> Yossi
> Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
> The Authority is happy to communicate in Welsh or English
> Website www.pembrokeshirecoast.org.uk
> Follow us on Twitter <http://twitter.com/PembsCoast>
> Join us on Facebook
> <http://www.facebook.com/group.php?gid=26330984774&ref=ts>
> Watch us on Youtube
> <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
> Look at us on Flickr <http://www.flickr.com/photos/pembrokeshirecoast/>
> This email and any attached files should only be read by those persons to
> whom
> they are addressed and be used by them only for their intended purpose.
> If you are not the intended recipient please destroy all copies and inform
> the
> sender by return email.
> Please note that the contents of this email may be subject to public
> disclosure
> under the Freedom of Information Act 2000 and therefore the
> confidentiality of
> this message and any reply cannot be guaranteed.
> Click here <http://www.pembrokeshirecoast.wales/default.asp?PID=413> to
> view PCNPA Privacy Notice – Keeping your Information Safe
> For further information on the PCNPA please visit our website at
> Please consider the environment before printing this email.
> Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw
> ffeiliau sydd
> ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y
> bwriadwyd hwy.
> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal â
> dinistrio pob copi a rhoi
> gwybod i'r anfonwr gyda throad yr e-bost.
> Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei
> ddatgelu i'r cyhoedd o
> dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd
> y neges hon
> nac unrhyw ateb.
> Cliciwch yma
> <http://www.pembrokeshirecoast.wales/default.asp?pid=413&LangID=2> i weld
> Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
> Am ragor o wybodaeth am APCAP ymwelwch â'n gwefan ar
> www.arfordirpenfro.org.uk
> Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
> Qgis-user mailing list
בברכה
יוסי רוקני
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180802/d1a9fa25/attachment.html>
