[Qgis-user] qgis 3 on CentOS
Matthias Kuhn matthias at opengis.ch
Fri Aug 3 02:31:30 PDT 2018
Hi Valentin,
Thank you for reporting this. The repository unfortunately no longer
exists and packages for QGIS 3 where never available there. The link
will be removed from the download page.
I am not sure if there is an alternative repository that offers it.
The situation with CentOS is often complicated because it has a long
lifetime and libraries used by QGIS are often old and outdated. I think
it *should* be possible to get it up and running with someone who is
able to compile, but if you have a choice, I would recommend to use
another distribution with Qt 5.10 or newer.
All the best
Matthias
On 08/02/2018 07:35 PM, Valentin wrote:
> I'm trying to install qgis on CentOS 7. I followed instruction on qgis
> download page however the repository (fedora.vitu.ch
> <http://fedora.vitu.ch>) seem to be broken.
> I made :
> sudo wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
> then this error message appear :
> Resolving fedora.vitu.ch <http://fedora.vitu.ch> (fedora.vitu.ch
> <http://fedora.vitu.ch>)... failed: Name or service not known
> wget: unable to resolve host adress âfedora.vitu.châ
> Any way to fix it or any alternative repository from where i can
> download qgis for CentOS ?
> Valentin
> Qgis-user mailing list
