[Qgis-user] Fwd: QGIS web map - add author name
Yossi Rokni
yossi.rokni at gmail.com
Sun Aug 5 04:53:14 PDT 2018
Found it.
I created a new template in C:\Users\username\.qgis2\qgis2web\templates
folder with the required author name.
Before I export (in version 2.18) the map, I select this template, and then
I export.
t works, even after updating the map with QGIS Desktop.
בתאריך יום ה׳, 2 באוג׳ 2018 ב-14:17 מאת Philip Barlow <
philipb at pembrokeshirecoast.org.uk>:
> Hi Yossi,
> No problem.
> Qgis2web used to have the option to use templates, where you would be able
> to add these kinds of things to the template so you wouldn’t have to
> manually add them each time. I don’t see that in the QGIS 3.x version. I’m
> sure Tom will be able to help there.
> Phil
> *From:* Yossi Rokni [mailto:yossi.rokni at gmail.com]
> *Sent:* 02 August 2018 11:33
> *To:* Philip Barlow
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Fwd: QGIS web map - add author name
> Thanks Phil,
> This really helped and solved the problem.
> However I have some issues:
> I worked according to your instructions and updated the index.html file -
> It solved the problem.
> But when I publish again the web map, I get a new index.html file without
> this manual update.
> I looked to the link you sent me in github. They discuss there doing this
> kind of manual update in the template. So I went to the templates files
> in C:\Users\username\.qgis2\qgis2web\templates folder and made this manual
> update in the template files.
> This solves the problem when I re-publish the map.
> But it doesn't solve the problem when I make an update in the map and save
> it in QGIS Desktop.
> I guess a solution for this requires an enhancement in QGIS Desktop.
> Per your advice I opened a new enhancement request on github.
> Thanks again
> Yossi
> בתאריך יום ה׳, 2 באוג׳ 2018 ב-11:19 מאת Philip Barlow <
> Hi Yossi,
> You could just add something like this to the index.html output at the
> bottom between </script> and the </body>?
> </div>
> <div style="position: fixed; left: 100px;
> top: 20px; background-color: white; opacity:0.6; padding:0px;z-index:2;">
> <h1>Your title</h1>
> </div>
> The z-index is important, make sure you add it to the div id for the map
> or else your title will be underneath your map and you won’t see it.
> Like this:
> <div id="map" style=*"**z-index:1**;">*
> You’ll find some more info here:
> https://github.com/tomchadwin/qgis2web/issues/415
> You could put in an enhancement request on github?
> Hope this helps.
> Phil
> *From**:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of* Yossi Rokni
> *Sent**:* 02 August 2018 06:57
> *To**:* qgis-user at lists.osgeo.org
> *Subject**:* [Qgis-user] Fwd: QGIS web map - add author name
> I created my first web map in QGIS, using the good instructions in this
> web page:
> https://www.qgistutorials.com/en/docs/web_mapping_with_qgis2web.html
> I want to add a fixed text
> (such as author's name)
> at the bottom of the map.
> Is it possible to do it by updating the file qgis2web.js or any other way?
> I am not familiar with java script - it would be great if you could
> provide me
> an example of
> the relevant java script command that I need to add into qgis2web.js.
> Some more details:
> I use QGIS version 2.18 (I tried using QGIS 3.0, but I couldn't create a
> web map in this version).
> I created the web map using qgis2web plugin.
> Thanks
> Yossi
> Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
> The Authority is happy to communicate in Welsh or English
> Website www.pembrokeshirecoast.org.uk
> Follow us on Twitter <http://twitter.com/PembsCoast>
> Join us on Facebook
> <http://www.facebook.com/group.php?gid=26330984774&ref=ts>
> Watch us on Youtube
> <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
> Look at us on Flickr <http://www.flickr.com/photos/pembrokeshirecoast/>
> This email and any attached files should only be read by those persons to
> whom
> they are addressed and be used by them only for their intended purpose.
> If you are not the intended recipient please destroy all copies and
> inform the
> sender by return email.
> Please note that the contents of this email may be subject to public
> disclosure
> under the Freedom of Information Act 2000 and therefore the
> confidentiality of
> this message and any reply cannot be guaranteed.
> Click here <http://www.pembrokeshirecoast.wales/default.asp?PID=413> to
> view PCNPA Privacy Notice – Keeping your Information Safe
> For further information on the PCNPA please visit our website at
> Please consider the environment before printing this email.
> Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw
> ffeiliau sydd
> ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd
> hwy.
> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal â
> dinistrio pob copi a rhoi
> gwybod i'r anfonwr gyda throad yr e-bost.
> Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei
> ddatgelu i'r cyhoedd o
> dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd
> y neges hon
> nac unrhyw ateb.
> Cliciwch yma
> <http://www.pembrokeshirecoast.wales/default.asp?pid=413&LangID=2> i weld
> Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
> Am ragor o wybodaeth am APCAP ymwelwch â'n gwefan ar
> www.arfordirpenfro.org.uk
> Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
> Qgis-user mailing list
> בברכה
> יוסי רוקני
> Join us on Facebook
> Watch us on Youtube
> whom
> If you are not the intended recipient please destroy all copies and inform
> the
> disclosure
> confidentiality of
> ffeiliau sydd
> bwriadwyd hwy.
> y neges hon
> nac unrhyw ateb.
> Cliciwch yma
בברכה
יוסי רוקני
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180805/f0c8be68/attachment.html>
