[Qgis-user] Support for DWG?
    Boaz Bar Ilan
    boazprosie at gmail.com
    Sun Aug  5 07:18:56 PDT 2018
hi
thanks
I didn't succeed importing
 I followed the instructions
it seems that the created geopackage file is not correct
is there accurate instruction ?
thanks
boaz
2018-08-02 15:53 GMT+03:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Micha,
> This is already implemeted quite a long time ago. You have to use Menu
> "Project" --> "Import/Export" --> "Import Layers from DWG/DXF".
> What it does: it imports the DWG/DXF into a geopackage and tries to keep
> styling and labeling as good as possible. DXF blocks are converted to SVGs.
> It should work fine in general, but of course there can be issues.
> The major thing I am still missing is an easy way to georeference vectors
> in QGIS, since many DWG/DXFs use a local coordinate system.
> Could you please report back if it works fine for you?
> Greetings,
> Andreas
> On 2018-08-02 14:43, Micha Silver wrote:
> Over the years the question of reading DWG format files has come up [1].
> And there was even a crowd funding campaign some years ago [2] . Andreas'
> initial design requirements document [3] is still sitting on google docs.
> Does anyone have some update on this?
> Thanks,
> Micha
> [1] https://lists.osgeo.org/pipermail/qgis-user/2016-October/038043.html
> [2] https://blog.qgis.org/2015/12/08/crowd-funding-project-for-
> reading-cad-documents-in-qgis/
> [3] https://docs.google.com/document/d/1NJv1lwd5TnWdV-
> fTuW7g5ts1O8r3vb46xYeAIQ_BwGw/edit
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> +972-523-665918
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180805/b9e3158e/attachment.html>
