[Qgis-user] Textual representation of styles ?
Andreas Neumann a.neumann at carto.net
Tue Aug 7 07:12:31 PDT 2018
Hi Lars,
QGIS supports "data defined" properties. Any graphical attribute is
usually also exposed as "data-defined".
Wherever you can defined this data-defined icon (see
https://docs.qgis.org/2.18/en/_images/mIconDataDefine.png) you can
either specify a feature attribute or rule or calculation to define a
property.
See also
https://docs.qgis.org/2.18/en/docs/user_manual/introduction/general_tools.html#data-defined
So - if your data contains attributes that can be used for symbology,
you can apply such data-defined overrides.
OGR feature styles are not directly supported by QGIS, but if they are
exposed in one or more attributes, you may use this information for
Hope this helps,
Andreas
Am 07.08.2018 um 15:49 schrieb Lars I. Nielsen, LIFA A/S:
> Hi list.
> Does QGIS utilize and support textual styles, e.g. as read from data ?
> OGR has a feature style specification
> (https://www.gdal.org/ogr_feature_style.html ), with some examples
> shown below.
> Has anyone used QGIS to facilitate such style representation ?
> /Here are some example style definition strings: /
>   * /A 5 pixels wide red line:
>     //PEN(c:#FF0000,w:5px)///
>   * /A polygon filled in blue, with a black outline:
>     //BRUSH(fc:#0000FF);PEN(c:#000000)///
>   * /A point symbol:
>     //SYMBOL(c:#00FF00,id:"points.sym-45,ogr-sym-7")///
>   * /A text label, taking the text string from the "text_attribute"
>     attribute field:
>     //LABEL(f:"Times New Roman",s:12pt,t:{text_attribute})"///
> /Here is what a style table that contains all the above styles could
> look like: /
> /    road: PEN(c:#FF0000,w:5px)/
> /lake:      BRUSH(fc:#0000FF);PEN(c:#000000)/
> /campsite:  SYMBOL(c:#00FF00,id:"points.sym-45,ogr-sym-7")/
> /label:     LABEL(f:"Times New Roman",s:12pt,t:{text_attribute})/
> I know that QGIS supports its own XML style format, and supports some
> form of SLD. Both are layer based, though, not feature based.
> Med venlig hilsen
> GIS konsulent, FME Certified Professional
> Beskrivelse: http://website.lifa.dk/docs/LIFA_GIS·IT_logo.png
> *T*
> 6313 6800
> lin at lifa.dk
> *D*
> 6313 6849
> *W*
> www.lifa.dk <http://www.lifa.dk>
> *M*
> 2492 4866
> *Vi tilbyder interne og eksterne kurser. Du kan finde mere information
> i vores **kursuskalender <https://www.lifa.dk/kursuskalender>
> **Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-Images-Get-L749-l8.png*
> <https://www.linkedin.com/company/lifa-a-s/>
> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S Landinspektører
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180807/f44d4ed8/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180807/f44d4ed8/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180807/f44d4ed8/attachment-0001.png>
