[Qgis-user] localisation of date fails in QGIS 3.2
Frank Broniewski
hallo at frankbroniewski.com
Thu Aug 9 01:47:24 PDT 2018
My take on getting the locale from Qt and setting it in Python:
import locale
def get_qgis_locale():
loc = QLocale()
for lang in loc.uiLanguages():
if lang.startswith(loc.bcp47Name()):
return '%s.UTF-8' % lang.replace('-', '_')
return 'en_US.UTF-8'
locale.setlocale(locale.LC_ALL, get_qgis_locale())
print(locale.getlocale())
uiLanguages() is a bit ambiguous, when using auto locale it just shows ‘de’ for me, setting
the override – not the user interface – to nl_BE it shows ‘nl-BE’ which should be enough for setting locale.setlocale, you just need to replace the dash with an underscore. There is still the possibility that this will break on some language combinations though.
Frank
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Alessandro Pasotti
Gesendet: Donnerstag, 9. August 2018 09:30
An: Reginald Carlier <Reginald.Carlier at ingelmunster.be>
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] localisation of date fails in QGIS 3.2
On Thu, Aug 9, 2018 at 9:23 AM, Reginald Carlier <Reginald.Carlier at ingelmunster.be <mailto:Reginald.Carlier at ingelmunster.be> > wrote:
Thanks a lot Alessandro,
That works perfectly.
Glad it helped.
btw, this is a side-effect of the recent changes in QGIS locale: we are now using setting a "default locale" (from QGIS settings) when QGIS starts, and that locale is used through the whole QGIS application.
If you change the default locale in the settings, please remember to restart QGIS.
Reginald Carlier
Deskundige GIS
<https://www.ingelmunster.be/>
<https://www.ingelmunster.be/> Gemeente Ingelmunster
<https://www.ingelmunster.be/> ,
<https://www.ingelmunster.be/> Oostrozebekestraat 4
<https://www.ingelmunster.be/> 8770
<https://www.ingelmunster.be/> Ingelmunster
<https://www.ingelmunster.be/> T
<https://www.ingelmunster.be/> +32 51 33 74 39
<https://www.ingelmunster.be/> www.ingelmunster.be
<https://www.ingelmunster.be/> Raadpleeg onze disclaimer
<https://www.ingelmunster.be/> Van: Alessandro Pasotti [mailto:apasotti at gmail.com]
Verzonden: donderdag 9 augustus 2018 9:10
Aan: Reginald Carlier
CC: Nyall Dawson [via OSGeo.org]; qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] localisation of date fails in QGIS 3.2
<https://www.ingelmunster.be/> Reginald,
<https://www.ingelmunster.be/> Using QT:
<https://www.ingelmunster.be/> locale = QLocale(QLocale.Japanese)
<https://www.ingelmunster.be/> locale.toString(QDate.currentDate())
<https://www.ingelmunster.be/> And, if you want to use the same settings that you set in QGIS, just use the default locale:
<https://www.ingelmunster.be/> locale = QLocale() # Default locale from QGIS options/settings
<https://www.ingelmunster.be/> On Thu, Aug 9, 2018 at 8:54 AM, Reginald Carlier <Reginald.Carlier at ingelmunster.be> wrote:
<https://www.ingelmunster.be/> I forgot to mention that I import datetime as follows:
<https://www.ingelmunster.be/> from datetime import datetime
<https://www.ingelmunster.be/> In the console I get the same result as from my script.
<https://www.ingelmunster.be/> Maybe I should use QCoreApplication.translate or some other explicit way to tell python to translate a string from English to Dutch?
<https://www.ingelmunster.be/> Regards,
<https://www.ingelmunster.be/> Reginald Carlier
<https://www.ingelmunster.be/> Deskundige GIS
<https://www.ingelmunster.be/> Fout! Bestandsnaam niet opgegeven.
<https://www.ingelmunster.be/> Van: Nyall Dawson [via OSGeo.org] [mailto:ml+s1560n5373899h69 at n6.nabble.com]
Verzonden: donderdag 9 augustus 2018 8:43
Onderwerp: Re: localisation of date fails in QGIS 3.2
<https://www.ingelmunster.be/> On Thu, 9 Aug 2018 at 16:39, Reginald Carlier
> Hi Nyall,
> Somehow my post shows the code but my previous post doesn't.
> Anyway this is how the code looks:
> vandaag = datetime.now()
> dag = vandaag.day
> maand = vandaag.strftime("%B")
> jaar = vandaag.year
> datum = str(dag) + " " + maand + " " + str(jaar)
> I suspect that maybe strftime changed in python 3.6?
Do you see the same from a standalone python console? (I'm not sure
that this issue is related to QGIS at all or whether it's a Python
specific thing).
Nyall
Qgis-user mailing list
[hidden email]
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
_____
<https://www.ingelmunster.be/> If you reply to this email, your message will be added to the discussion below:
<https://www.ingelmunster.be/> http://osgeo-org.1560.x6.nabble.com/localisation-of-date-fails-in-QGIS-3-2-tp5372703p5373899.html
<https://www.ingelmunster.be/> To start a new topic under QGIS - User, email ml+s1560n4125267h77 at n6.nabble.com
To unsubscribe from QGIS, click here.
NAML
Qgis-user at lists.osgeo.org
<https://www.ingelmunster.be/> Alessandro Pasotti
w3: www.itopen.it
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180809/90ad653f/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180809/90ad653f/attachment.bin>
