[Qgis-user] points to polygon
Antonio Silva
aolinto.lst at gmail.com
Wed Aug 15 16:43:33 PDT 2018
Thanks Franks, I found the scripts and I will try them.
Regards
Antonio Olinto
Em qua, 15 de ago de 2018 às 07:08, Frank Broniewski <
hallo at frankbroniewski.com> escreveu:
> Hi Antonio,
> there are two tools in the processing toolbox which might help you. For
> one there’s the points to line (qgis:pointstopath) script and second the
> lines to polygons (qgis:linestopolygons) script which might do what you
> want.
> Best,
> Frank
> *Von:* Qgis-user <qgis-user-bounces at lists.osgeo.org> * Im Auftrag von *Antonio
> Silva
> *Gesendet:* Dienstag, 14. August 2018 23:01
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] points to polygon
> Hi,
> I'm trying to make polygons from a set of points in QGIS Bonn 3.2.1 under
> Ubuntu 18.04.
> I was used to do this with Points2One but I couldn't find this complement
> any more.
> Is there any other option?
> Thanks a lot.
> All the best
> Antonio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180815/a506365c/attachment.html>
