[Qgis-user] What Plug in does live GPS input in QGIS?
    Brent Wood
    Brent.Wood at niwa.co.nz
    Tue Aug 21 23:42:57 PDT 2018
HI,
The QGIS panel allows you to manually save individual GPS points to a currently open & editable point layer - a mouse click on the button does this. Upon saving a point, you will be presented with a dialogue box to enter the values for any fields (attributes) defined in the map layer.
There is also a check box in the pane to log the NMEA GPS data to file. You can then use a Python QGIS NMEA plugin (nmea2qgis2) to open the saved GPS NMEA data file, and optionally save as a shapefile. This is an experimental plugin, so you will need to enable these.
I just used this plugin today - and found a bug in the python code which incorrectly converts southern hemisphere latitudes to decimal degrees, but this is a simple fix, & I'll email the author to hopefully fix the code. Prior to this I used an awk script to convert the GGA lines in a QGIS GPS log file to points, with a counter allowing them to be ordered and easily turned into a line by another QGIS plugin (Points2One).
Hope this helps...
Brent Wood
Programme leader: Environmental Information Delivery
NIWA
DDI:  +64 (4) 3860529
[cid:image28d6a3.PNG at 8dea1a7a.47832349]<http://www.niwa.co.nz>
Brent Wood
Principal Technician - GIS and Spatial Data Management
Programme Leader - Environmental Information Delivery
T +64-4-386-0529
301 Evans Bay Parade, Greta Point, Wellington
Connect with NIWA: niwa.co.nz<https://www.niwa.co.nz> Facebook<https://www.facebook.com/nzniwa> Twitter<https://twitter.com/niwa_nz> LinkedIn<https://www.linkedin.com/company/niwa> Instagram<https://www.instagram.com/niwa_science>
To ensure compliance with legal requirements and to maintain cyber security standards, NIWA's IT systems are subject to ongoing monitoring, activity logging and auditing. This monitoring and auditing service may be provided by third parties. Such third parties can access information transmitted to, processed by and stored on NIWA's IT systems.
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Joep Orbons <j.orbons at archeopro.nl>
Sent: Wednesday, August 22, 2018 17:40
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] What Plug in does live GPS input in QGIS?
Hi all,
The QGIS plugin "GPS tools" imports and exports GPX files. But I need a plug in to live grab GPS data. I connect my GPS to an USB port. The GPS sends continuously an ASCII string with GPS data and I would like to visualise the live data on a QGIS map and store points when I hit a functionkey. A sort of surveyors tool. Anyone any ideas?
Thanks
Joep
[logo ArcheoPro Algemeen, Mailsize]
drs. ing. Joep Orbons
Senior Archeoloog, Senior Specialist Geofysica
St Jozefstraat 45, 6245 LL Eijsden
Tel: +31 43 3672586
email: j.orbons at archeopro.nl<mailto:j.orbons at archeopro.nl>
Web: www.archeopro.nl<http://www.archeopro.nl/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180822/92929ef5/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180822/92929ef5/attachment.jpg>
Type: image/png
Desc: image28d6a3.PNG
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180822/92929ef5/attachment.png>
