[Qgis-user] vector tools of Grass failed in Qgis 3 Mac os
Mensio Federico
mensio at ipla.org
Wed Aug 22 01:09:24 PDT 2018
Now it's works. in effect there was an error when i write the PATH
variable... Thank you so much.
2018-08-21 23:12 GMT+02:00 William Kyngesburye <woklist at kyngchaos.com>:
> Did you follow the instructions in the Readme to add an environment
> variable? It's needed for this very reason - external scripts (GRASS,
> GDAL, ...) can't find python without it.
> On Aug 21, 2018, at 5:07 AM, Mensio Federico <mensio at ipla.org> wrote:
> Its' seems a problem of Python. Some solution?
> Algorithm 'v.clean' starting…
> Parametri in ingresso:
> { '-b' : False, '-c' : False, 'GRASS_MIN_AREA_PARAMETER' : 0.0001,
> 'GRASS_OUTPUT_TYPE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' : None,
> 'GRASS_SNAP_TOLERANCE_PARAMETER' : 1, 'GRASS_VECTOR_DSCO' : '',
> 'GRASS_VECTOR_LCO' : '', 'error' :
> '/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/510564a2b8db42e393e2254640a879ae/error.shp',
> 'input' : '/progetti/temp/suoli_test.shp', 'output' :
> '/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/16c02a3f39974724bef28a376b3e63ca/output.shp',
> 'threshold' : '1', 'tool' : [0], 'type' : [0,1,2,3,4,5,6] }
> g.proj -c proj4="+proj=utm +zone=32 +datum=WGS84 +units=m +no_defs"
> v.in.ogr min_area=0.0001 snap=1.0 input="/progetti/temp/suoli_test.shp"
> output="vector_5b7be41acf0d87" --overwrite -o
> g.region n=5068419.991296747 s=4905848.379899999 e=521593.56898278
> w=350249.30290076975
> v.clean input=vector_5b7be41acf0d87
> type="point,line,boundary,centroid,area,face,kernel" tool="break"
> threshold="1" output=output10c76cc109c14eca860414df206c8505
> error=error10c76cc109c14eca860414df206c8505 --overwrite
> v.out.ogr -c type="auto" input="output10c76cc109c14eca860414df206c8505"
> output="/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/16c02a3f39974724bef28a376b3e63ca/output.shp"
> format="ESRI_Shapefile" --overwrite
> v.out.ogr -c type="auto" input="error10c76cc109c14eca860414df206c8505"
> output="/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/510564a2b8db42e393e2254640a879ae/error.shp"
> env: python3: No such file or directory
> Esecuzione completata in 0.64 secondi
> Risultati:
> {'error': <QgsProcessingOutputLayerDefinition
> {'sink':/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/510564a2b8db42e393e2254640a879ae/error.shp,
> 'createOptions': {'fileEncoding': 'System'}}>,
> 'output': <QgsProcessingOutputLayerDefinition
> {'sink':/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/16c02a3f39974724bef28a376b3e63ca/output.shp,
> 'createOptions': {'fileEncoding': 'System'}}>}
> Federico MENSIO
> IPLA spa
> Corso Casale, 476 - 10132 Torino
> <https://maps.google.com/?q=Corso+Casale,+476+-+10132+Torino&entry=gmail&source=g>
> Mobile +39.340.06.01.363
> TEL +39.011.432.0443 FAX +39.011.89.89.333
> mensio at ipla.org - www.ipla.org
> Questa e-mail è personale e i suoi contenuti contengono informazioni
> riservate ai destinatari. Pertanto la lettura, copia od altro uso da parte
> di altri o qualsiasi altra azione derivante dalla conoscenza di queste
> informazioni sono rigorosamente vietate e perseguibili ai sensi del Dlgs
> 196/03.
> Qualora abbiate ricevuto questo documento per errore siete cortesemente
> pregati di darne immediata comunicazione al mittente ai riferimenti
> indicati e provvedere immediatamente alla sua distruzione.
> Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa mail
> Qgis-user mailing list
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
Federico MENSIO
IPLA spa
196/03.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180822/77ad0b6b/attachment.html>
