[Qgis-user] Case
Andreas Neumann
a.neumann at carto.net
Thu Aug 23 23:26:04 PDT 2018
Hi Edisson,
Not sure if you are really using QGIS? The screenshot you pasted from
the attribute table seems to be from another GIS (ESRI?).
Anyway - your CASE statement is wrong - no matter if it concerns QGIS or
ESRI, you cannot have several tests, separated by Kommas. Either you
have to combine the tests with AND/OR or you have to use the IN/NOT IN
statements, e.g. like
CASE
WHEN val IN (1,3,5,7) THEN 'odd'
WHEN val IN (2,4,6,8) THEN 'even'
END
The syntax you used is invalid.
Hope this helps, no matter what GIS is concerned ;-)
Greetings,
Andreas
Am 23.08.2018 um 22:04 schrieb Eddison Araya:
> Hello, greetings, a question:
> If I have that map:
> *https://www.dropbox.com/s/6hvnrb37fvc00wl/ejemplo.zip?dl=0 *
> E eu quero dizer:
> Se W_BRILLO is equal to 3, se W_PPT is equal to 1, se W_TEMP is equal
> to 2, have a value of 2
> Se W_BRILLO is equal to 2, se W_PPT is equal to 2, se W_TEMP
> is equal to 3, have a value of 2
> Se W_BRILLO is equal to 1, se W_PPT is equal to 2, se W_TEMP is
> equal to 3, have a value of 3
> I put this:
> CASE
> WHEN "W_BRILLO" = '3', "W_PPT" ='1', "W_TEMP" = '2' THEN 2
> WHEN "W_BRILLO" = '2', "W_PPT" ='2', "W_TEMP" = '3' THEN 2
> WHEN W_BRILLOI = '1', "W_PPT" ='2', "W_TEMP" = '3' THEN 3
> END
> But I get an error!
> Thank you
> Eddison
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180824/ed17e610/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180824/ed17e610/attachment.png>
