[Qgis-user] Case
Eddison Araya
eddisonjose at gmail.com
Fri Aug 24 06:49:06 PDT 2018
Hi, if I'm using QGIS, only that was a screenshot that was sent to me at
the beginning.
I can not send the image because the size is large, I attach the image
here: * https://ibb.co/b15WF9 <https://ibb.co/b15WF9>*
regards
Eddison
El vie., 24 ago. 2018 a las 0:26, Andreas Neumann (<a.neumann at carto.net>)
escribió:
> Hi Edisson,
> Not sure if you are really using QGIS? The screenshot you pasted from the
> attribute table seems to be from another GIS (ESRI?).
> Anyway - your CASE statement is wrong - no matter if it concerns QGIS or
> ESRI, you cannot have several tests, separated by Kommas. Either you have
> to combine the tests with AND/OR or you have to use the IN/NOT IN
> statements, e.g. like
> CASE
> WHEN val IN (1,3,5,7) THEN 'odd'
> WHEN val IN (2,4,6,8) THEN 'even'
> END
> The syntax you used is invalid.
> Hope this helps, no matter what GIS is concerned ;-)
> Greetings,
> Andreas
> Am 23.08.2018 um 22:04 schrieb Eddison Araya:
> Hello, greetings, a question:
> [image: image.png]
> If I have that map: *https://www.dropbox.com/s/6hvnrb37fvc00wl/ejemplo.zip?dl=0
> <https://www.dropbox.com/s/6hvnrb37fvc00wl/ejemplo.zip?dl=0> *
> E eu quero dizer:
> Se W_BRILLO is equal to 3, se W_PPT is equal to 1, se W_TEMP is equal to
> 2, have a value of 2
> Se W_BRILLO is equal to 2, se W_PPT is equal to 2, se W_TEMP is
> equal to 3, have a value of 2
> Se W_BRILLO is equal to 1, se W_PPT is equal to 2, se W_TEMP is
> equal to 3, have a value of 3
> I put this:
> CASE
> WHEN "W_BRILLO" = '3', "W_PPT" ='1', "W_TEMP" = '2' THEN 2
> WHEN "W_BRILLO" = '2', "W_PPT" ='2', "W_TEMP" = '3' THEN 2
> WHEN W_BRILLOI = '1', "W_PPT" ='2', "W_TEMP" = '3' THEN 3
> END
> But I get an error!
> Thank you
> Eddison
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180824/6bcf5eee/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180824/6bcf5eee/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180824/6bcf5eee/attachment-0001.png>
