[Qgis-user] Identify features doesn't work on Qgis 3.2.2 for Mac
Jesús Lopez
jesusl.temez at gmail.com
Wed Aug 29 07:29:36 PDT 2018
Despite the problem with map area issue on mac, there is a new problem in 3.2.2 that neither it’s present on 3.2. The identify features option does not work correctly. If you click on any object on the map (with the layer selected) nothing appears on the identify panel. Only if you open the contextual menu (right click) you can get the info. I have seen this behavior on OS X 10.11.6 and 10.13.6, both with QGIS 3.2.2-1 and Python 3.6.6. Any idea?
