[Qgis-user] putting a script that doesn't involve GUI in	scripts toolbox
    Reginald Carlier
    Reginald.Carlier at ingelmunster.be
    Thu Aug 30 01:02:29 PDT 2018
Thanks Nyall,
This will get me on the right track. :)
Regards,
Reginald Carlier
Deskundige GIS
Gemeente Ingelmunster, Oostrozebekestraat 4, 8770 Ingelmunster
T+32 51 33 74 39www.ingelmunster.be
Raadpleeg onze disclaimer
Van: Nyall Dawson [via OSGeo.org] [mailto:ml+s1560n5375927h37 at n6.nabble.com]
Verzonden: dinsdag 28 augustus 2018 11:45
Aan: Reginald Carlier
Onderwerp: Re: putting a script that doesn't involve GUI in scripts toolbox
On Tue, 28 Aug 2018 at 18:43, Reginald <[hidden email]</user/SendEmail.jtp?type=node&node=5375927&i=0>> wrote:
> Thanks Havard,
> So I guess this means that it is impossible to use python scripts without
> opening a dialog?
That's not correct - the dialog is shown if your algorithm defines any
input parameters which require user interaction. If you remove all the
input parameters from your algorithm, then no dialog is shown and the
algorithm/script is run immediately.
Nyall
Qgis-user mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5375927&i=1>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/putting-a-script-that-doesn-t-involve-GUI-in-scripts-toolbox-tp5375911p5375927.html
To start a new topic under QGIS - User, email ml+s1560n4125267h77 at n6.nabble.com
To unsubscribe from QGIS, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4099105&code=UmVnaW5hbGQuQ2FybGllckBpbmdlbG11bnN0ZXIuYmV8NDA5OTEwNXw3OTAxNjMzMzQ=>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180830/03fa033a/attachment.html>
