[Qgis-user] Identify features doesn't work on Qgis 3.2.2 for Mac
    Jesús Lopez
    jesusl.temez at gmail.com
    Fri Aug 31 02:56:06 PDT 2018
I try it again this morning. Sometimes, randomly, the first time you open a file, identify features works correctly, but in consecutive openings (without closing Qgis) it stops working to me.
> El 30 ago 2018, a las 17:14, Garth Fletcher <garth at jacqcad.com> escribió:
> Jesús Lopez <jesusl.temez at gmail.com> wrote:
>> Despite the problem with map area issue on mac, there is a new problem in 3.2.2 that neither it’s present on 3.2. The identify features option does not work correctly. If you click on any object on the map (with the layer selected) nothing appears on the identify panel. Only if you open the contextual menu (right click) you can get the info. I have seen this behavior on OS X 10.11.6 and 10.13.6, both with QGIS 3.2.2-1 and Python 3.6.6. Any idea?
> Identify Features seems to work here with QGIS-macOS-3.2.2-1 downloaded this morning and running under Mac OS X 10.12.6 (Sierra).
> About QGIS info appended.
> Garth Fletcher
> <QGIS-macOS-3.2.2-1_about.jpg>_______________________________________________
> Qgis-user mailing list
