[Qgis-user] QGIS 3.4.2 still very slow to work in Windows 10
Antongeo76 antoviscomi at gmail.com
Tue Dec 11 01:03:55 PST 2018
Saber Razmjooei wrote
> It's been said a lot and often gets dismissed by users (similar to have
> you
> turn off and on your computer), but most of the issues can be resolved by:
> 1- Start your QGIS 3, with a clean profile.
> 2- Remove/disable all 3rd party plugins
> If all fails, report the bug with a sample data and step-by-step to
> reproduce the issue.
> Regards
> Saber
> On Mon, 10 Dec 2018 at 17:49, Bernd Vogelgesang <
> bernd.vogelgesang@
> wrote:
>> Hi,
>> I can't contribute to your particular problems, but have some remarks.
>> You said you "reverted" to 2.18. On Windows, you can easily run 3.x
>> besides 2.x. Do you have the same problems with 2.18?  If so, it's
>> really your personal installation that fails, I think.
>> The node tool was redesigned in 3.x, and there is quite a discussion
>> going on, cause not so many people like the new behaviour.
>> In general, I would like to say, that the promotion of the newest
>> release shown in QGIS is quite a bad idea: The inexperienced will not
>> hesitate to update and therefore run in every possible bug, being left
>> clueless, while the more experienced are more cautious and install it
>> only anlongside for testing purposes first.
>> The developers are in a bad situation: They need lots of testers to find
>> bugs, but in my opinion they reach the wrong users with that
>> advertisement. (no idea how to improve this)
>> Furthermore, the new version had a bad start, cause (as I understood)
>> last-minute-changes in dependencies caught them unprepared.
>> Unfortunately, no one gives warnings about the major issues somewhere
>> prominently e.g. on the QGIS.org website, so you have to read the
>> mailing-list(s) and search in the issue queue yourself. In my opinion,
>> in QGIS3 the developers were a little too ambitious, but it seems they
>> also had kind of bad luck as well. Lots of features introduced are
>> somewhat bleeding-edge and need time to ripe.
>> As I rarely use Windows, I'm not of big help. I just want to recommend
>> you to use the network installer (advanced install!) and install the 2.x
>> LTR and the 3.x LTR in parallel and update them through the installer
>> once in a while, and keep 2.18 for productive work as long as you do not
>> trust the 3.x version.
>> The open source mantra is "release early, release often", but that
>> doesn't mean that everyone has to update early and often as well!
>> Cheers,
>> Bernd
>> Am 10.12.18 um 17:59 schrieb David Addy:
>> > I have always loved QGIS and I have extolled its virtues to local
>> historians
>> > and archaeologists in my area.
>> > I have had to keep quiet about it lately.
>> > I was somewhat relieved to hear a comment on a recent video of the
>> Oceania
>> > meeting that QGIS 3.4.1 was a dud release as it caused Windows to crash
>> at
>> > random moments. I had thought that all the long pauses, messages of
>> QGIS
>> not
>> > responding, and crashing when being closed down was some awful feature
>> > unique to my computer. I had even tried reverting to 2.18 for a while.
>> > However, after I upgraded to 3.4.2 I still had problems.
>> > Opening QGIS on Windows 10 can take over half a minute before anything
>> > happens apart from the outline box of the QGIS window full of blank
>> space.
>> > Once a project finally loads up any random operation can still get the
>> "QGIS
>> > not responding" message.
>> > This can result in further issues because I try pressing buttons to get
>> a
>> > response.
>> > I even bought Anita's 4th edition of "Learn QGIS" to see if I was doing
>> > something radically wrong. It did highlight a few wrinkles until I got
>> to
>> > page 55 when I discovered instructions on the edit node tool. This tool
>> I
>> > had used OK in the past, but it now baffles me totally. I cannot get it
>> to
>> > do what the book says.
>> > I am now losing my confidence in 3.4.2 and can only hope that the next
>> point
>> > release will produce improvements.
>> > It would really help if known major issues like this could be posted
>> here,
>> > perhaps as a sticky which stays at the top, to let users know that they
>> are
>> > not alone with an issue.
>> > Sorry to complain.
>> > Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> > _______________________________________________
>> > Qgis-user mailing list
> Qgis-user at .osgeo
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user at .osgeo
> Saber Razmjooei
> www.lutraconsulting.co.uk
> Qgis-user at .osgeo
Hi Saber,
these issues also appear on clean installations with fresh start...
the reports of these are often considered like local problems by the
developers...
Moreover, these freezes are difficult to reproduce because it is difficult
to communicate
via screencast a freeze (for a simple "save as") for 5min or more ...
during these freezes, if you check the system resources, you realize that
RAM and CPU used by QGIS are static.
So the user thinks he is doing QGIS if it does not respond but does not use
resources?
All this with 2.18 does not happen with the same data and the same
operations
Best Regards
Antonio
