[Qgis-user] how to properly reference longitude values in different datasets
Lee Eddington
lee.w.eddington at gmail.com
Thu Dec 20 05:00:31 PST 2018
Can you point me to the external tools?
Thanks,
Lee
> On Dec 20, 2018, at 12:46 AM, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk> wrote:
> This is a known issue and can be fixed with some external tools.
> I have filed a bug:
> https://issues.qgis.org/issues/20853 <https://issues.qgis.org/issues/20853>
> And hopefully get around to fix it in 3.6
> Regards
> Saber
> On Thu, 20 Dec 2018 at 01:44, Lee Eddington <lee.w.eddington at gmail.com <mailto:lee.w.eddington at gmail.com>> wrote:
> I’m pretty new to QGIS and am trying to figure out how to modify longitude values of layers. I was able to add a raster layer in GRIB2 format (NCEP global meteorological data). The longitude values range from 0 to 360 degrees. I’m able to view and do calculations on the data with no problem. I also added shaded relief and coastline data from Natural Earth. This data has longitude values from -180 to 180 degrees. So from -180 to 0 degrees I only see the Natural Earth data, from 0 to 180 degrees I see both datasets and from 180 to 360 degrees I only see the GRIB2 data. I want both datasets to be referenced the same with regards to longitude (-180 to 180, 0 to 360 or whatever). It seems like this should be a fairly easy problem to fix by either adding 180 degrees to longitudes from the Natural Earth data or subtracting 180 from the GRIB2 longitudes, but I can’t figure out how to do it.
> I’m using QGIS version 3.4.1-Madeira. The CRS I’m working in is what QGIS put the GRIB2 data into when I added it: * Generated CRS (+proj=longlat +a=6371229 +b=6371229 +no_defs)
> Thanks,
> Lee
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Saber Razmjooei
> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
> +44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181220/c073b07e/attachment.html>
