[Qgis-user] qgis/postgis : flow map
image laurent.celati at gmail.com
Sat Feb 3 12:07:30 PST 2018
So, i succeed in executing the query without error message. The query
generates a temp postgis layer linear.
I attach the SS below showing the qgis canvas
<http://osgeo-org.1560.x6.nabble.com/file/t365144/6.jpg>
But i have always a problem regarding the GROUP BY...i would like to do a
GROUP BY one field only...but i can't generate the query without put all
fields present in SELECT into GROUP BY !
Please read my currently query :
create table temp as select
st_makeline(st_makepoint(entrants_v2.x_resi,entrants_v2.y_resi),st_makepoint(entrants_v2.x_tr,entrants_v2.y_tr))as
geometry,sum(entrants_v2.ipondi) as sumipondi, entrants_v2.codgeo_res as
codgeo_res, entrants_v2.codgeo_tr as codgeo_tr
from entrants_v2
group by
entrants_v2.codgeo_res,entrants_v2.x_resi,entrants_v2.y_resi,entrants_v2.x_tr,entrants_v2.y_tr,entrants_v2.ipondi,entrants_v2.codgeo_tr
Is it a way to assign one field into group by with postgis? Because my
result is false.
In advance, thank you very much.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
