[Qgis-user] Idea: Crowd-sourcing a batch-georeferencer plugin withQR code ?
Nyall Dawson nyall.dawson at gmail.com
Sat Feb 3 14:35:38 PST 2018
On 4 February 2018 at 06:32, Alex Mandel <tech_dev at wildintellect.com> wrote:
> I think you undervalue what's been done. See the code base, and
> re-use/adapt whatever components you want. You can run your own custom
> version.
> https://github.com/fieldpapers
> Could even integrate it with QGIS as a plugin, or flip that around and
> use QGIS server to create the tile layer used in the background.
Hmm, let's do the math:
- QGIS 3.0 composer adds support for plugin-based item types, allowing
Python plugins to add new items to a layout
- fieldpapers is open source, so easy to see and reproduce the logic
regarding what's embedded in those QR codes
- there's existing Python libraries for QR codes as images, which
could then easily be rendered inside a QGIS 3.0 QgsLayoutItem subclass
Go forth magic QGIS plugin authoring elves! Do your thing!
Nyall
