[Qgis-user] Google Satellite Images v3
Stefan Giese
Stefan.Giese at wheregroup.com
Mon Feb 12 00:30:41 PST 2018
Hi Tobias,
I don't think so, but I am not sure. I didn't find anything about this in the term of usage. If you publish something, sure you have to follow the terms of use and put the attribution on your maps...
best
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSS Academy Kompaktkurs Winterschule 2018
Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
https://www.foss-academy.com/schulungstermine/kompaktkurs-winterschule
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 12.02.2018 um 09:16 schrieb Tobias Wendorff:
> Hi Stefan,
> Am Mo, 12.02.2018, 08:54 schrieb Stefan Giese:
>> you can load them directly as an xml file (see attached xml).
>> Add Raster data->then pick the xml file...
> Isn't this against Google's terms of usage to directly access
> the tiles without using the API?
> Best regards,
> Tobias
