[Qgis-user] Google Satellite Images v3
Jürgen E. Fischer
jef at norbit.de
Mon Feb 12 00:30:58 PST 2018
Hi Tobias,
On Mon, 12. Feb 2018 at 09:16:00 +0100, Tobias Wendorff wrote:
> Am Mo, 12.02.2018, 08:54 schrieb Stefan Giese:
> > you can load them directly as an xml file (see attached xml).
> > Add Raster data->then pick the xml file...
> Isn't this against Google's terms of usage to directly access
> the tiles without using the API?
I think it is. Usage via the QuickMapServices plugin is in the same gray area.
Not sure if usage via the OpenLayers plugin is either - that's at least using
the API, but using browser components in background is probably also not the
intended usage - but probably dark white.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180212/4eb268ca/attachment.sig>
