[Qgis-user] Mac OS X testing for QGIS 3
    Burghardt.Scholle at stadt.wolfsburg.de
    Wed Feb 14 23:23:09 PST 2018
Hi John,
thank you for your nice reply. I'm just a QGIS user and work primarily under Linux and Windows. But for testing purposes, I frequently use my MacBook Air. So I will continue trying to get QGIS 3 running on Mac OS X.
Regards
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: John Harrop [mailto:jcharrop at gmail.com]
> Gesendet: Mittwoch, 14. Februar 2018 18:21
> An: Scholle, Burghardt (15-3 GIS)
> Cc: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] Mac OS X testing for QGIS 3
> Burghardt,
> Thanks for the pointers, they seen much more up to date than the older
> ones pointed to by the QGIS web site.
> I’ve been trying to build from the notes since you posted your suggestion
> and I see what you mean about the matplotlib problem. I forked the Mac OS
> X build notes on GitHub and started to work on them to see if I could get a
> working set for the matplotlib problems but not much luck.  However, I do
> seem to have it installed through pip or otherwise, so I worked past that step
> and have been trying to get CMake to configure a makefile but there are
> problems there as well.  I fixed a missing library by manually installing but I’m
> now having problems with Qt5Positioning which is not being found.
> its been a while since I was active in configuring build systems so I’m having
> to clean off the dust in my memories and learn newer versions of the
> systems.
> I get the impression that not much has been going on with Mac OS X dev
> builds for at least a few months and quite a few dependancies have changed
> over that time.  I’ll keep working on this and hopefully there are some other
> GIS testers also interested in the Macs.
> Let me know if you are still trying to get the Mac OS X dev build working or if
> you have had success.
> Regards,
> John Harrop
> > On Feb 8, 2018, at 10:22 PM, Burghardt.Scholle at stadt.wolfsburg.de wrote:
> > Hi John,
> > I believe there is no current complete dmg-file for QGIS3-dev. But you can
> use the excellent site under [1] to install QGIS3-dev using Homebrew.
> Unfortunately, there are problems with the matplotlib dependency at the
> moment (see [2]). Yersterday I've tried to install the current version but it
> failed.
> > Even so I hope that my hints help.
> > Regards
> > Burghardt
> > [1]
> > https://github.com/qgis/homebrew-
> qgisdev/blob/master/development/READM
> > E.md [2] https://github.com/qgis/homebrew-qgisdev/issues/50
> >> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag
> >> von John Harrop
> >> Gesendet: Donnerstag, 8. Februar 2018 19:53
> >> An: qgis-user at lists.osgeo.org
> >> Betreff: [Qgis-user] Mac OS X testing for QGIS 3
> >> Hello,
> >> Is it possible to be involved in OS X testing of the QGIS 3 beta?
> >> There are parts of the web site that suggest it is, but I have not
> >> been able to find a web age for up to date downloads.
> >> Thanks,
> >> John Harrop
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
