[Qgis-user] Mac OS X testing for QGIS 3
John Harrop jcharrop at gmail.com
Thu Feb 15 11:03:01 PST 2018
That was a badly written email I rushed off previously.  I should have included more specific information:
The errors turning up now during make config are
1)
CMake Error at cmake/FindQwt.cmake:47 (FILE):
  FILE failed to open for reading (No such file or directory):
    /opt/local/libexec/qt5/include/qwt/qwt_global.h
Call Stack (most recent call first):
  CMakeLists.txt:231 (FIND_PACKAGE)
I do have qwt61 installed; rolling back to qwt did not fix the error
2)
  File "/Users/john/src/QGIS/cmake/FindQsci.py", line 45, in <module>
    from PyQt5.Qsci import QSCINTILLA_VERSION_STR
ImportError: No module named 'PyQt5.Qsci’
Having trouble finding where to get this or what it comes with.  I have qscintilla-qt5 installed.  Do I need qscintilla as well?  That seems to be Qt4.
3)
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
PYTHON_LIBRARY
    linked by target "qgispython" in directory /Users/john/src/QGIS/src/python
SPATIALINDEX_LIBRARY
    linked by target "qgis_core" in directory /Users/john/src/QGIS/src/core
Doesn’t seem to help if I add these as environment variables; as if make is ignoring or overriding the environment.
John Harrop
> On Feb 15, 2018, at 10:26 AM, John Harrop <jcharrop at gmail.com> wrote:
> Gradually moving forward  adding installing missing ports.  Other than Homebrew I notice that the Anaconda compiler is being found first.  I’m still getting problems running make config with both PYTHON_LIBRARY and SPATIALINDEX_LIBRARY coming back as not found.  Would this be a problem caused by Anaconda?  Does a python need to be under ports for the make to work?
> Thanks,
> John Harrop
> jcharrop at gmail.com <mailto:jcharrop at gmail.com>
>> On Feb 14, 2018, at 12:58 PM, David Liontooth <lionteeth at cogweb.net <mailto:lionteeth at cogweb.net>> wrote:
>> Hi John,
>> Good question. MacPort keeps most things in /opt/local/, so if homebrew puts files elsewhere you could likely install in parallel and switch by changing $PATH in ~/.profile.
>> Here's what .profile looks like after a MacPorts installation, with GNU tools switched to MacPorts:
>> # MacPorts Installer adding an appropriate PATH variable for use with MacPorts.
>> export PATH=/opt/local/bin:/opt/local/sbin:/opt/local/libexec/gnubin/:$PATH
>> Cheers,
>> David
>> On 2/14/18 12:30 PM, John Harrop wrote:
>>> That looks interesting David.  Thanks.
>>> How much uninstall on Homebrew is recommended before switching to this MacPorts?  The work looks quite active on MacPorts but I don’t see much on potential Homebrew or Anaconda conflicts.
>>> John Harrop
>>>> On Feb 14, 2018, at 11:52 AM, David Liontooth <lionteeth at cogweb.net <mailto:lionteeth at cogweb.net>> wrote:
>>>> Vincent at Macports has done a great job packaging qgis3, cf. https://trac.macports.org/ticket/55020 <https://trac.macports.org/ticket/55020>
>>>> grass7 was just upgraded to 7.4, postgresql10 to 10.2.
>>>> qgis3 is at 20180124.
>>>> Cheers,
>>>> David
>>>> On 2/14/18 11:18 AM, Madry, Scott wrote:
>>>>> Hi all.
>>>>> As a dedicated Mac QGIS user, trainer, and research. I want to put in a plea to keep the Mac OS development process on pace. There are many of us out there who use the Mac OS version, and we need to get these issues with matplotlib, GRASS, and others addresses so that we have a good 3.0 rollout.
>>>>> I would be happy to assist with testing, thanks for all your efforts,
>>>>> Scott
>>>>> Scott Madry, Ph.D.
>>>>> Research Associate Professor of Archaeology
>>>>> The University of North Carolina at Chapel Hill
>>>>> Tel         1-919-448-4493
>>>>> Email: madrys at email.unc.edu <mailto:madrys at email.unc.edu> <mailto:madrys at email.unc.edu <mailto:madrys at email.unc.edu>>
>>>>> https://scottmadry.web.unc.edu <https://scottmadry.web.unc.edu/>
>>>>> Skype:   scott madry
>>>>>> On Feb 14, 2018, at 12:20 PM, John Harrop <jcharrop at gmail.com <mailto:jcharrop at gmail.com> <mailto:jcharrop at gmail.com <mailto:jcharrop at gmail.com>>> wrote:
>>>>>> Burghardt,
>>>>>> Thanks for the pointers, they seen much more up to date than the older ones pointed to by the QGIS web site.
>>>>>> I’ve been trying to build from the notes since you posted your suggestion and I see what you mean about the matplotlib problem. I forked the Mac OS X build notes on GitHub and started to work on them to see if I could get a working set for the matplotlib problems but not much luck.  However, I do seem to have it installed through pip or otherwise, so I worked past that step and have been trying to get CMake to configure a makefile but there are problems there as well.  I fixed a missing library by manually installing but I’m now having problems with Qt5Positioning which is not being found.
>>>>>> its been a while since I was active in configuring build systems so I’m having to clean off the dust in my memories and learn newer versions of the systems.
>>>>>> I get the impression that not much has been going on with Mac OS X dev builds for at least a few months and quite a few dependancies have changed over that time.  I’ll keep working on this and hopefully there are some other GIS testers also interested in the Macs.
>>>>>> Let me know if you are still trying to get the Mac OS X dev build working or if you have had success.
>>>>>> Regards,
>>>>>> John Harrop
>>>>>>> On Feb 8, 2018, at 10:22 PM, Burghardt.Scholle at stadt.wolfsburg.de <mailto:Burghardt.Scholle at stadt.wolfsburg.de> wrote:
>>>>>>> Hi John,
>>>>>>> I believe there is no current complete dmg-file for QGIS3-dev. But you can use the excellent site under [1] to install QGIS3-dev using Homebrew.  Unfortunately, there are problems with the matplotlib dependency at the moment (see [2]). Yersterday I've tried to install the current version but it failed.
>>>>>>> Even so I hope that my hints help.
>>>>>>> Regards
>>>>>>> Burghardt
>>>>>>> [1] https://github.com/qgis/homebrew-qgisdev/blob/master/development/README.md <https://github.com/qgis/homebrew-qgisdev/blob/master/development/README.md>
>>>>>>> [2] https://github.com/qgis/homebrew-qgisdev/issues/50 <https://github.com/qgis/homebrew-qgisdev/issues/50>
>>>>>>>> -----Ursprüngliche Nachricht-----
>>>>>>>> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org>] Im Auftrag von
>>>>>>>> John Harrop
>>>>>>>> Gesendet: Donnerstag, 8. Februar 2018 19:53
>>>>>>>> An: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>>>>>>>> Betreff: [Qgis-user] Mac OS X testing for QGIS 3
>>>>>>>> Hello,
>>>>>>>> Is it possible to be involved in OS X testing of the QGIS 3 beta?  There are
>>>>>>>> parts of the web site that suggest it is, but I have not been able to find a web
>>>>>>>> age for up to date downloads.
>>>>>>>> Thanks,
>>>>>>>> John Harrop
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-user mailing list
>>>>>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180215/55f280a0/attachment.html>
