[Qgis-user] Qgis won't start after Crash. Missing qgis-bin.exe
nils.hempel at gmx.de nils.hempel at gmx.de
Tue Feb 20 22:18:32 PST 2018
Richard,
thank you for your answer. I found the cause for my trouble in my virus scanner who somehow decided that the qgis-bin.exe is infected and moved it into a quarantine folder. Undoing this solved the issue.
However, the crash appeared when I was using the qgis.v.upgrade module in the qgis GRASS extension. If the crash  was caused by my virus scanner or if the behavior of it was a result of the crash I cannot tell.
Thanks again,
Regards,
Nils
Von: Richard McDonnell [mailto:richard.mcdonnell at opw.ie]
Gesendet: Dienstag, 20. Februar 2018 15:21
An: nils.hempel at gmx.de; qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Qgis won't start after Crash. Missing qgis-bin.exe
Nils,
Is there a file similar to this your_project_name.qgs~, where "your_project_name" is replaced by your shortcut/project name, if so, this would be a solution, rename it to something like project_name_2.qgs  and open it. I hope this solves the issue.
Regards,
Richard.
On 20/02/2018 13:29, nils.hempel at gmx.de <mailto:nils.hempel at gmx.de>  wrote:
Hi all,
today I was using QGis until it crashed. Now it will not start, telling me the qgis-bin.exe is missing. I’ve restarted my computer several times now but still the error remains.
I’ve start qgis with the same link not less then one hour ago and I certaintly didn’t delete any .exe files. Does anyone knows if there are lock files which can cause this error?
Cheers,
Nils
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Richard McDonnell
GIS Specialist PgD GIS AssocSCSI
OPW FRM Data Management
52 Stephens Green, Dublin 2.
TEL: 01 6476543
 <http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180221/d4c1cca3/attachment.html>
