[Qgis-user] PY QGIS crashing when using numpy
Luigi Pirelli luipir at gmail.com
Mon Feb 26 11:31:34 PST 2018
I tested on 2.18.16 and your code works
Probably a conflicts on GDAL versions? btw You are not using any
pyqgis call that can conflicts.
YOu can start trying to execute the commands line by line and discover
what command crash qgis... and check also if gdal.__version__ values
match that listed in qgis help->about
just y 2c
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On 26 February 2018 at 18:48, Giacomo Fontanelli
<giacomofontanelli76 at gmail.com> wrote:
> Hi forum
> each time I try to write a code using the numpy library, qgis crashes and
> quits, so I can't geyt any relevant information about my error.
> This happen when I use qgis 2.18.16 in Lubuntu 16.04.
> For example, if I try to run this very small script
> import numpy as np
> from osgeo import gdal
> ds = gdal.Open("/home/giacomo/Dropbox/Linux/VHVV.tif")
> myarray = np.array(ds.GetRasterBand(1).ReadAsArray()
> Qgis quits.
> The strange thing is that it doesn't happen when I launch the same script in
> QGIS 2.18.15 in Windows 10.
> Any help
> Thank you
> Qgis-user mailing list
