[Qgis-user] No 3D menu item
    Bernd Vogelgesang
    bernd.vogelgesang at gmx.de
    Sat Jan  6 04:07:30 PST 2018
Hi Andreas,
do you know if there is a recommended way to get qt5.9?
It seems not be available from the standard repositories.
Will try to do it this way:
https://linuxhint.com/install-qt-5-9-1-qt-creator-4-3-1-ubuntu/
Cheers
Bernd
Am 06.01.2018, 12:46 Uhr, schrieb Andreas Neumann <a.neumann at carto.net>:
> Hi Bernd,
> or a missing dependency.
> Check for any qt5-qt3d packages (there are several) and your 3d
> functionality might magically appear. Also you need at least qt5.9 for
> it to work. Check if this is satisfied.
> Andreas
> On 06.01.2018 12:37, Bernd Vogelgesang wrote:
>> Hi,
>> just wanted to try the new 3D functionalities, but surprisingly, there
>> is no menu item under the View-menu where I read it is supped to be.
>> Running ubuntugis-nigthlies on Ubuntu 16.04. Everything else seems to
>> be in place an running well.
>> Bug or feature?
>> Cheers
>> Bernd
> Qgis-user mailing list
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
