[Qgis-user] ctrl-c selection issue
Kirk Schmidt
kirk at nortekresources.com
Tue Jan 9 13:19:56 PST 2018
After a few selections, you may have to close and reopen qgis to purge
the memory as well. Importing a csv is memory intensive so another
approach is to try saving as a spatial database (SQLite) or even a
shapefile. Once written, you can load the spatial file and you should
have lots of memory to keep selecting points.
Kirk
On 1/9/2018 4:58 PM, Ramon Andinach wrote:
> I’m not sure what the problem is, but if I were doing that repeatedly,
> I’d probably use Layer -> Save As, tick the Save Only Selected
> Features box and save it to CSV. Then muck about with excel later.
> This way ought to be a bit lighter on the memory.
> Ramon.
>> On 10 Jan 2018, at 04:25, Jeroen Hovens <mail at groenebij.nl
>> <mailto:mail at groenebij.nl>> wrote:
>> Hi,
>> Using qgis 2.14.18 I have been working today with a large csv file
>> (7.5 mln objects). I just need selections of this database which I
>> can then modify in excel. So I opened the attribute table and made a
>> selection based on a specific value for an attribute, and copied that
>> selection (about 30.000 objects) via the clipboard (ctrl-c) to a new
>> Microsoft Excel file, then saved the excel file and repeated the
>> process for another selection. This worked perfect for some time.
>> However, some selections won’t copy: when I press the copy button the
>> programs turn to ‘not responding’ and won’t snap out of it anymore.
>> Selection size when this happens is about the same (about 20k to 35k
>> objects).
>> What could be the problem? Could the data be corrupted? How can I
>> check what is wrong?
>> Thank you
>> Gr.
>> Jeroen
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekreources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180109/7a556d83/attachment.html>
