[Qgis-user] ctrl-c selection issue
    Mike Flannigan
    mikeflan at att.net
    Sat Jan 13 17:23:59 PST 2018
I would recommend not using Excel to modify CSV files.  That
program has a reputation for changing numbers to dates and
performing other modifications to the file contents that may
not be wanted.
Personally I use the Text::CSV module in Perl, but there are
many other methods to modify a CSV file without the changes that
Excel imposes on you.
Mike
On 1/9/2018 4:37 PM, qgis-user-request at lists.osgeo.org wrote:
> Hi,
> Using qgis 2.14.18 I have been working today with a large csv file (7.5 mln
> objects). I just need selections of this database which I can then modify in
> excel. So I opened the attribute table and made a selection based on a
> specific value for an attribute, and copied that selection (about 30.000
> objects) via the clipboard (ctrl-c) to a new Microsoft Excel file, then
> saved the excel file and repeated the process for another selection. This
> worked perfect for some time. However, some selections won't copy: when I
> press the copy button the programs turn to 'not responding' and won't snap
> out of it anymore.  Selection size when this happens is about the same
> (about 20k to 35k objects).
> What could be the problem? Could the data be corrupted? How can I check what
> is wrong?
> Thank you
> Gr.
> Jeroen
