[Qgis-user] Generating black white from RGB landsat using	Raster Map calculator?
    Chas Sheen
    chassheengeo at gmail.com
    Wed Jan 17 03:52:16 PST 2018
Richard,
I should have made my initial query clearer.
I am trying to output a black and white geotiff.
Have split the original (landsat) image into RGB images.
When I apply the expression in the capture below, and hit run, nothing is saved to the results directory.
I’m assuming that my expression or something else in the raster calculator is wrong?
The final product that I’m after is a xyz grid where z is the black-white amplitude…which I think should be relatively easy (?) once I have the black-white image.
Chas Sheen
0448017282
From: Richard McDonnell [mailto:richard.mcdonnell at opw.ie]
Sent: Wednesday, January 17, 2018 7:13 PM
To: Chas Sheen <chassheengeo at gmail.com>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Generating black white from RGB landsat using Raster Map calculator?
Chas,
Two options for splitting RGB into separate images in QGIS.
1.	Semi-Automatic Classification Plugin, Preprocessing, Split Raster Bands
2.	Grass r-rgb (Processing Toolbox)
Any one of these tools will split the Raster for you easy enough
Regards,
Richard
On 17/01/2018 00:48, Chas Sheen wrote:
I split the image into R, G, B
Worked out in QGIS wher the Raster map calculator is.
Run...several times
No result foud in Results Directory. It runs quickly then refreshes inputs and logs to blanks.
I'm new to QGIS....so have probably left out something basic.
Any clues
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Richard McDonnell
GIS Specialist PgD GIS AssocSCSI
OPW FRM Data Management
52 Stephens Green, Dublin 2.
TEL: 01 6476543
 <http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180117/19ffc8de/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180117/19ffc8de/attachment.png>
