[Qgis-user] Shape file to xyz where z is label
    Chas Sheen
    chassheengeo at gmail.com
    Sun Jan 21 15:02:18 PST 2018
Stefan,
It looks at though this generates a shape file of the centroids (pink dots
below).
[image: Inline images 1]
What I was after was an xyz file of the data where z is lithology so that I
can fill the shapefile polygons with a lithology colour/pattern in my
software.
Chas
On 19 January 2018 at 14:56, Stefan Giese (WhereGroup) <
stefan.giese at wheregroup.com> wrote:
> Hi Chas,
> you can use Vector-Menu->Geometry Tools->Polygon centroids
> which will produce a pointlayer with all attributes. There you will find
> your label as one column like in the geology layer.
> best
> stefan
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Das WhereGroup-Team wünscht Ihnen ein frohes
> Weihnachtsfest und ein glückliches Jahr 2018!
> Die Termine der FOSS Academy für 2018 sind online!
> Alle Infos unter www.foss-academy.com
> WhereGroup GmbH & Co. KG
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Am 2018-01-19 06:07, schrieb Chas Sheen:
>> I have a shape file of geology where the label represents lithology.
>> Is there a way to export xyz where z is the label.
>> Then I could display result in other software.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180122/38934709/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180122/38934709/attachment.png>
