[Qgis-user] Debian/Ubuntu repositories on qgis.org - https vs http
Richard Duivenvoorde
rdmailings at duif.net
Tue Jan 30 22:45:08 PST 2018
On 30-01-18 23:58, Alister Hood wrote:
> Hi everyone,
> I followed the instructions
> at https://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu to
> install from https://qgis.org/ubuntugis, and I found that apt-get update
> gave me "handshake failed" errors unless I used http instead of https.
> This might be because I am testing under WSL, so not really a normal
> linux environment, but I just wanted to check - does https normally work
> for people?
Hi Alister,
https://qgis.org/ubuntugis/ is being served via Cloudflare, and you get
a https certificate via them.
if you use: https://ubuntu.qgis.org/ubuntugis/ you do NOT go via
Cloudflare, can you check if that works for you. (and if maybe do a
pull request to fix docs?)
Regards,
