[Qgis-user] Debian/Ubuntu repositories on qgis.org - https vs	http
    Alister Hood
    alister.hood at gmail.com
    Wed Jan 31 15:56:32 PST 2018
Hi again,
On 31 January 2018 at 19:45, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 30-01-18 23:58, Alister Hood wrote:
> > Hi everyone,
> > I followed the instructions
> > at https://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu to
> > install from https://qgis.org/ubuntugis, and I found that apt-get update
> > gave me "handshake failed" errors unless I used http instead of https.
> > This might be because I am testing under WSL, so not really a normal
> > linux environment, but I just wanted to check - does https normally work
> > for people?
> Hi Alister,
> https://qgis.org/ubuntugis/ is being served via Cloudflare, and you get
> a https certificate via them.
> if you use: https://ubuntu.qgis.org/ubuntugis/ you do NOT go via
> Cloudflare, can you check if that works for you. (and if  maybe do a
> pull request to fix docs?)
It seems Richard is right - https://ubuntu.qgis.org/ubuntugis/ works and
https://qgis.org/ubuntugis/ does not.
But Jürgen reported that it does work for him, which is perplexing.
When I installed again later in the day (for a later version of Ubuntu),
from http://qgis.org/ubuntugis-nightly/, I was having problems with the
packages downloading quite slowly or timing out - I guess the server was
overloaded. Perhaps the docs should mention both https://ubuntu.qgis.org/
ubuntugis/ and http://qgis.org/ubuntugis/ if they are on different servers.
Regards,
Alister
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180201/1fb55db8/attachment.html>
