[Qgis-user] [EXTERNAL] Re: Not query geometry types in layer browser?
Richard McDonnell
richard.mcdonnell at opw.ie
Mon Jul 2 09:23:57 PDT 2018
Bryan,
I was having a similar issue before, it was due in my case to QGIS
looking through the whole table to find what kinds of Geometry were in
the table. In my case the addition of Geometry Constraints helped speed
things greatly.
The only other way I know, which is quicker for loading Tables (if you
have already added them as sources) would be to:
In QGIS 2.1X use the DB Manager, and drag and drop the Layers you want
into QGIS, its considerably quicker, also good for adding views!
In QGIS 3.X, you can use the Data Source Manager to add the Layers, Dont
use the icons on the Left (thats the same as the method you are having
issues with), drill down through the Browser instead, you can add them
from there, I find it much quicker. Again its a good method for adding
Views.
Hope it helps, Regards,
Richard.
On 02/07/2018 17:03, Bryan Hall wrote:
> Classification: DCL-Internal
> Richard,
> Yes, I understand how to do that, and this is not the issue.
> The problem I have is that when I open the database connection, the
> layer/table list polls the database for each and every accessible
> item. That takes considerable time (I let it finish – the runtime was
> about an hour and a half).
> I am asking if there is a configuration setting to disable this lookup
> (beyond just polling the mdsys.sdo_geom_metadata_table for the
> schema/table/column names) so that I can just open the browser, select
> a table, and go on without waiting for it to load metadata about all
> the other tables into the browser first.
> Bryan
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Richard McDonnell
> *Sent:* Monday, July 02, 2018 08:59
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [EXTERNAL] Re: [Qgis-user] Not query geometry types in
> layer browser?
> Hi,
> If I understand your question correctly.
> I have little experience in Oracle DB's, but in PostgreSQL/PostGIS,
> you can create a Geometry Constraint within your table, which states
> what geometry is within the table, which speeds up QGIS in reading
> table lists, when loading them.
> A quick search online resulted in
> https://docs.oracle.com/database/121/SPATL/constraining-data-geometry-type.htm#SPATL584
> <https://urldefense.proofpoint.com/v2/url?u=https-3A__docs.oracle.com_database_121_SPATL_constraining-2Ddata-2Dgeometry-2Dtype.htm-23SPATL584&d=DwMDaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=kMsobCS1r-dtfVBLfC8RZmbtJAznC8lfOANCQ5nwhA8&s=S9z0VtIEHJoE-2R25LFRmKsUNxZRFR9i7AgsQo4TRmc&e=>
> Hope this helps!
> Regards,
> Richard.
> Is there a way to configure QGIS to not query the geometry types
> from each registered shape with an Oracle database when opening
> the layer browser?
> I ask because the database I am trying to load data from has 1486
> registered tables, for which about 100 are external data (csv)
> tables (much slower to query), and a few dozen are huge collection
> geometry tables. QGIS currently takes “forever” (more than an hour
> – I gave up waiting) for the layer browser to query and load all
> the entries into the list. I really like QGIS in general, but this
> issue makes it unusable as it is currently.
> Thanks in advance,
> Bryan
> This email (and attachments if any) is intended only for the use
> of the individual or entity to which it is addressed, and may
> contain information that is confidential or privileged and exempt
> from disclosure under applicable law. If the reader of this email
> is not the intended recipient, or the employee or agent
> responsible for delivering this message to the intended recipient,
> you are hereby notified that any dissemination, distribution or
> copying of this communication is strictly prohibited. If you have
> received this communication in error, please notify the sender
> immediately by return email and destroy all copies of the email
> (and attachments if any).
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> <https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_qgis-2Duser&d=DwMDaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=kMsobCS1r-dtfVBLfC8RZmbtJAznC8lfOANCQ5nwhA8&s=caiUu-DvTuzd2TmfpjqNUppla10STsmQTtMQAtHX0Ig&e=>
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> *_Richard McDonnell_*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> Image removed by sender.
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.opw.ie_&d=DwMDaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=kMsobCS1r-dtfVBLfC8RZmbtJAznC8lfOANCQ5nwhA8&s=C0r94_8VGOQDxvOdlZYMEBO-Vy0MTJzZdEdGu6Mpm8A&e=>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.opw.ie_en_disclaimer_&d=DwMDaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=kMsobCS1r-dtfVBLfC8RZmbtJAznC8lfOANCQ5nwhA8&s=IA7mnpK0OpnLwBH204WtogeLT4aBNUz0C_yyA0Lm-AU&e=>
> This email (and attachments if any) is intended only for the use of
> the individual or entity to which it is addressed, and may contain
> information that is confidential or privileged and exempt from
> disclosure under applicable law. If the reader of this email is not
> the intended recipient, or the employee or agent responsible for
> delivering this message to the intended recipient, you are hereby
> notified that any dissemination, distribution or copying of this
> communication is strictly prohibited. If you have received this
> communication in error, please notify the sender immediately by return
> email and destroy all copies of the email (and attachments if any).
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180702/ae858dfa/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180702/ae858dfa/attachment.jpe>
