[Qgis-user] Iterating two layers in Report - QGIS 3.2
Carlos Cerdán sig.upagu at gmail.com
Wed Jul 4 06:20:23 PDT 2018
Thank you very much Frank.
Yes, it's an excellent post, I've read it to learn new Report features.
My issue are labels: I would like to hide them if they are out of the
feature that is being iterated, especially when there are various labeled
layers... Well i've used plan B: satellite imagenery from quickmapservice
as base, which is masked by iterated polygon which has no fill;  and white
labels that are hidden by white fill of polygons that are not iterated.
Regards
Carlos
2018-07-04 1:28 GMT-05:00 Frank Broniewski <hallo at frankbroniewski.com>:
> Hi Carlos,
> did you find Nyalls excellent post on Reports in QGIS 3 already? I believe
> it explains what you want do achieve. Have a look at [1]
> [1] https://north-road.com/2018/01/23/exploring-reports-in-
> qgis-3-0-the-ultimate-guide/
> Hth,
> Frank
> Dipl. Geogr. Frank Broniewski
> Waldhölzbacher Str. 51
> <https://maps.google.com/?q=Waldh%C3%B6lzbacher+Str.+51+66679+Losheim+am+See&entry=gmail&source=g>
> 66679 Losheim am See
> 06872 509 068 4
> 0176 611 26 9 2 6
> www.frankbroniewski.com
> *Von:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *Im Auftrag von *Carlos
> Cerdán
> *Gesendet:* Dienstag, 3. Juli 2018 16:49
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] Iterating two layers in Report - QGIS 3.2
> Hi list
> I would like to make a report (atlas) iterating two layers where:
> 1. Layer of level 2 administrative boundary is iterated (with atlas
> feature) and shows it as a no filled polygon, with out label;  and else
> polygons as white filled with labels;  and
> 2. Layer of administrative level 3 boundary is iterated too (with atlas
> feature), and shows labels only in polygons that are intersected or are
> within the active level 2 boundary.
> How can be this done in QGIS 3.2? I was succsefull in QGIS 2.18, but now
> it doesn't work. I've tryed rules as:
>  intersects(@atlas_geometry,$geometry )
> contains(geometry(@atlas_feature),centroid( $geometry ) ) is true
> but nothing.
> I'm tring this because of non desired labels of level 3 boundary. One
> solutiion is using white labels that are fused with white polygons of level
> 2 boundary... but it is plan B.
> Any advice please?
> Cheers!
> Carlos Cerdan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180704/1ac873dc/attachment.html>
