[Qgis-user] Save label position in 3.2
C Hamilton
adenaculture at gmail.com
Sat Jul 7 12:55:12 PDT 2018
Lene,
The "Lat Lon Tools" plugin has a function that will save a point layer
geometry into attribute fields. I don't know if that is what you need or
not, but if so you will see it under "Plugins->Lat Lon
Tools->Conversions->Geometry to Field". There is a lot of flexibility with
it.
Calvin
On Sat, Jul 7, 2018 at 2:49 AM, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi Richard,
> Thanks a lot – this worked. Now I have labels on the roads.
> https://qgiscloud.com/UAS_KU/tur/?e=705743%3B6213558%
> 3B708994%3B6215150&crs=EPSG%3A25832&t=tur&l=DTK%2Fkort25%
> 20klassisk%2Cvejnavn%2Clang_rute%2Ckort_rute%2Csteder&st=
> But I still would like to know how to retrieve the coordinates in the
> attribute table.
> Kind regards
> Lene Fischer
> *Fra:* Richard McDonnell [mailto:richard.mcdonnell at opw.ie]
> *Sendt:* 6. juli 2018 12:04
> *Til:* qgis-user at lists.osgeo.org
> *Cc:* Lene Fischer
> *Emne:* Re: [Qgis-user] Save label position in 3.2
> Lene,
> *Hold the Press*!!!!, I take back my last email!! Hope its not too late!!!
> I have a solution for you!
> https://gis.stackexchange.com/questions/288170/qgis-3-2-0-
> how-to-share-auxiliary-data-between-projects
> Use QGIS 3 to create the additional fields with the field calculator, see
> examples below
> for example:
> *Field Name Field Type
> Expression*
> lab_x Decimal (Real) (20,4)
> "auxiliary_storage_labeling_positionx"
> lab_y Decimal (Real) (20,4)
> "auxiliary_storage_labeling_positiony"
> lab_rot Decimal (Real) (20,4)
> "auxiliary_storage_labeling_labelrotation"
> Then set up the Auxiliary fealds to use your new attributes, this should then work for QGISCloud!!
> Regards,
> Richard.
> On 06/07/2018 10:30, Richard McDonnell wrote:
> Hi,
> It seems, as QGIS 3 is not LTR yet, its not fully supported by QGISCloud.
> The only solution seems to be, to open the project in QGIS 2.18, add the
> x,y and rotation attribution and relocate/rotate your labels again.
> Sorry I cant be of more help.
> Regards,
> Richard.
> On 06/07/2018 09:53, Lene Fischer wrote:
> Yes this is correct – but only if you move the labels – What I want is the
> position for the labels without editing.
> I need this for web presentation. When I export to QGISCLOUD the labels is
> not presented – so I have to make a workaround…
> Regards
> Lene Fischer
> <richard.mcdonnell at opw.ie>]
> *Sendt:* 6. juli 2018 10:23
> *Til:* Lene Fischer
> Hi Lene,
> In QGIS 2.1X If you create X,Y and rotation attributes, when you use the
> move or rotate labels tools, the attribution is automatically updated. I
> would assume its the same!, though open to correction!
> Hope this helps.
> Regards
> On 06/07/2018 09:12, Lene Fischer wrote:
> Hi,
> I´m using 3.2 and trying out the label function. Wonderful new possibilities!
> I would like to save the z, y and rotation for the labels, but I can only get the information for labels I have edited in the "auxiliary_storage_labeling_positionx".
> Are there any other way to capture the positions ?
> Regards
> Lene Fischer
> Associate Professor
> University of Copenhagen
> Department of Geoscience and Natural Resource Management
> Forest and Landscape College
> Nødebovej 77a
> 3480 Fredensborg
> Denmark
> MOB +45 40115084
> lfi at ign.ku.dk
> Qgis-user mailing list
> *Richard McDonnell*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> *Richard McDonnell*
> TEL: 01 6476543
> *Richard McDonnell*
> TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180707/4f9d1c6e/attachment.html>
