[Qgis-user] Python error when trying to do a slope analysis in a DEM raster file
Frank Broniewski
hallo at frankbroniewski.com
Tue Jul 10 00:59:01 PDT 2018
Hi Larry,
it’s difficult to tell what went wrong without knowing the steps and the data you used. I just tried all the slope algorithms in the toolbox (gdal:slope, qgis:slope) and all work nicely here. I use QGIS 3 from the OSGeo4W-Installation … used a projected (in meters) SRTM scene and had no troubles running the slope algorithms.
Frank
Dipl. Geogr. Frank Broniewski
Waldhölzbacher Str. 51
66679 Losheim am See
06872 509 068 4
0176 611 26 9 2 6
<http://www.frankbroniewski.com> www.frankbroniewski.com
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von larry mason
Gesendet: Montag, 9. Juli 2018 19:29
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Python error when trying to do a slope analysis in a DEM raster file
<https://mailtrack.io/trace/mail/4790cfbaf39d64c696d840259962559ef60d0b91.png?u=651070>
I know I should read the documentation just not sure where to find it. I'm trying to do a slope analysis of a DEM raster layer... I get the following python stack trace:
snip---------------
An error has occurred while executing Python code:
AttributeError: 'slope' object has no attribute 'preprocessParameters'
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\gui\menus.py", line 181, in
action.triggered.connect(lambda: _executeAlgorithm(alg))
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\gui\menus.py", line 227, in _executeAlgorithm
dlg = alg.createCustomParametersWidget(None)
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\algs\gdal\GdalAlgorithm.py", line 62, in createCustomParametersWidget
return GdalAlgorithmDialog(self)
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\algs\gdal\GdalAlgorithmDialog.py", line 58, in __init__
self.mainWidget().parametersHaveChanged()
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\algs\gdal\GdalAlgorithmDialog.py", line 110, in parametersHaveChanged
parameters = self.parent.getParameterValues()
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\gui\AlgorithmDialog.py", line 119, in getParameterValues
return self.algorithm().preprocessParameters(parameters)
Python version: 3.6.0 (v3.6.0:41df79263a11, Dec 23 2016, 08:06:12) [MSC v.1900 64 bit (AMD64)]
QGIS version: 3.0.0-Girona Girona, 001c80b0c3
end snip-----------------------
So I'm wondering if I need to set anything up for QGIS is use python modules. Or where one sets up preprocessing Parameters. Any good tutorials on loading DEMs. configuring properties, and running analysis. Thanks,
Larry
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality6&>
Sender notified by
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality6&> Mailtrack 07/09/18, 12:25:29 PM
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180710/c42782d0/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180710/c42782d0/attachment.bin>
