[Qgis-user] Export segment values in polyline in excel
Alexandre Neto senhor.neto at gmail.com
Wed Jul 11 04:18:09 PDT 2018
Hello Daniel,
Use the explode lines tool in the processing toolbox before you use the
field calculator.
After that, you can simply copy all the segment features and copy it to
excel to paste the attribute table.
daniel pinto <daniel.ar.pinto at gmail.com> escreveu no dia quarta, 11/07/2018
às 10:36:
> Thank you, mas it it's not returnig the value of the segments, it's
> returting the total lenght.... i have more than 6000 segmnst to measure in
> diferenr polilines....  thank you anyway
> daniel pinto
> arqueólogo
> 91 869 1397
> rua de Arouca, nº 10, 1º esq, 3810-050 - Aveiro
> A sexta, 15/06/2018, 13:29, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> escreveu:
>> Hi,
>> Just use the field calculator to create a new column with the length.
>> Then you can save the file in csv and export it to Excel.
>> http://www.qgistutorials.com/en/docs/calculating_line_lengths.html
>> Nicolas
>> Le 15 juin 2018 à 07:48, daniel pinto <daniel.ar.pinto at gmail.com> a
>> écrit :
>> Dear sirs i have an image with several polylines to measure the elements
>> in need in said image.... i need to have the segments measure of each
>> polyline exported to excel... thru the atribute table... is that
>> possible???
>> Thank you in advance!!
>> daniel pinto
>> arqueólogo
>> 91 869 1397
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180711/b93dbe70/attachment.html>
