[Qgis-user] Provider Error
    Salvatore Larosa
    lrssvtml at gmail.com
    Fri Jul 13 08:15:10 PDT 2018
Il Ven 13 Lug 2018, 14:26 Martin Bittens <martin.bittens at gmx.de> ha scritto:
> Hello QGIS Users.
> I want to create a text field in an attribute table which contains some
> data points by using the field calculator. So I selected:
> - Create a new field
> - Output field name: Comment
> - Output field type: Text (string)
> - Output field length: 10
> - Text input: 'Area 2'
> The Output preview shows: 'Area 2'. By clicking on "OK" I receive the
> following message: "Could not add the new field to the provider"
> My system is: Windows 10, QGIS2.18.21.
> In the previous versions of QGIS I did not get that error when I added
> with the field calculator text fields in attribute tables.
> Does somebody know a solution solving the error?
> Thank you very much.
> Martin
this is a known issue [0] and there already is a patch to fix it [1].
A workaround that you could adopt before the patch get merged is changing
the precision value from 3 to 0 for the text field being created.
To change the precision value you have to select the decimal type before in
order to enable the spinbox widget.
Best Regards.
[0] - https://issues.qgis.org/issues/19283
[1] - https://github.com/qgis/QGIS/pull/7375
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180713/5ba22d64/attachment.html>
