[Qgis-user] QGIS 3 installation on Ubuntu
Patrick Dunford
enzedrailmaps at gmail.com
Mon Jul 16 18:58:59 PDT 2018
Hi there
The core development of Qgis is on Linux so it is very well supported on
that platform. In answer to your specific questions:
* Use the latest stable version of Ubuntu (18.04) - variants like
Lubuntu, Xubuntu etc also work well and may be more suited to specific
requirements.
1. The repositories labelled "debian" are for both Debian and Ubuntu -
you specify the release name in the deb statement which supports release
names for both distros.
2. You need to check error messages from the apt command if you get an
error when installing from an https repository. For example you may need
to install the package apt-transport-https to enable apt to work with
https repositorities. This is not an issue with the repository, it is an
issue with apt. The error message in this case is pretty descriptive as
to what is needed.
On 16/07/18 23:21, Mats Elfström wrote:
> Hi all!
> I am in need of some advice, because I am venturing into unknown
> territory. I want to explore the Linux side of QGIS, and I want to set
> up a Linux GIS machine (Cloud based). Bear with me, because my
> computing skills are in Microsoft territory. However, they date back
> from DOS days so I would say I am sufficiently computer literate.
> I have selected Ubuntu as platform, since I have some experience from
> that. Which version matters less, I have several to choose from on my
> Cloud provider.
> In the process, I am trying to piece together instructions and tips
> from different sources, of which the most reliable seems to be the
> ones at the qgis.org <http://qgis.org> site. However, there are some
> puzzling obstacles. I have tried using QGIS 3.2 Bonn, and Ubuntu 18.04
> bionic btw.
> 1/ For Ubuntu, I am adviced to load Debian repositories. There seems
> to be no Ubuntu folders. Are Ubuntu and Debian equal in this respect?
> 2/ The installer is unable to find ”deb-src https://qgis.org/debian
> bionic main”, while ”deb https://qgis.org/debian bionic main” worked
> fine. I carried on neverteless, but it seemed to give an incomplete
> installation.
> 3/ The instructions give the advice: ”In case you would like to
> install QGIS Server (note that it’s not a common practice to install
> both client and server applications on the same machine)…”
> Why is that? To me it would be common sense to install QGIS desktop
> and server on the same machine, to make sure that published map
> designs share the same paths and database connections. How else to
> ensure this? I have Windows servers with QGIS 2 desktop and server
> residing on the same machine with no problem.
> Furthermore, I plan to install Postgresql/Postgis on the same machine
> as well, for the same reason as above. Is that unsuitable too?
> Thankful for any advice, or links to a reliable installation manual.
> Note that i have scrapped the Cloud machines so far, so I cannot go
> back and test stuff. I always find it more reassuring to follow a
> straight path to success rather than going back for repairs at this stage.
> Regards, Mats.E
> ______________________________________________
> Mats Elfström, Väpplingvägen 21, SE-227 38 LUND, Sweden
> tel: +46 46 145959 / mob: +46 70 595 39 35
> alt e-mail: mats.elfstrom at giskraft.com <mailto:mats.elfstrom at telia.com>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180717/155b91d2/attachment.html>
