[Qgis-user] Qgis 3.2.0 crashes at DigitizingTools plugin activation.
Fernando M. Roxo da Motta
petro at roxo.org
Wed Jul 18 19:03:08 PDT 2018
Hi all,
I have just updated my machine to the Xubuntu 18.04 LTS:
$ lsb_release -a
LSB Version:
core-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
Distributor ID: Ubuntu Description: Ubuntu 18.04 LTS
Release: 18.04
Codename: bionic
The machine is a Asus Republic of Gamers:
$ uname -a
Linux cabore 4.15.0-24-generic #26-Ubuntu SMP Wed Jun 13 08:44:47 UTC
2018 x86_64 x86_64 x86_64 GNU/Linux
Upon installing Qgis it was offered the Qgis 3.2.0:
$ dpkg -l qgis
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Nome Versão Arquitectura Descrição
ii qgis 1:3.2.0+28bi amd64 Geographic Information
System (GI
Until the upgrade I was using the last inception Qgis 2.18 in the
Qgis stable repository:
$ cat /etc/apt/sources.list.d/qgis-stable.list
# http://www.qgis.org/en/site/forusers/alldownloads.html#ubuntu
deb http://qgis.org/debian bionic main
# deb-src http://qgis.org/debian trusty main
# nightly binaries.
# deb http://qgis.org/debian-nightly xenial main
I am still finding my way on this new version.
I have installed the DigitizingTools plugin from the oficial
repository. On start os Qgis the issues the mesage:
WARNING Plugin DigitizingTools : The plugin will be disabled
because it crashed QGIS during last startup. Please report an issue and
re-enable the plugin when the problem has been solved.
If I try to activate it in the Plugin Manager I got this message at
the terminal:
QGIS died on signal 11Could not attach to process. If your uid matches
the uid of the target process, check the setting
of /proc/sys/kernel/yama/ptrace_scope, or try again as the root user.
For more details, see /etc/sysctl.d/10-ptrace.conf ptrace: Operation
not permitted. No thread selected
No stack.
gdb returned 0
Aborted
Is there any procedure I should use to help detect what the problem
is?
Best regards.
Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
Except where explicitly stated I speak on my own behalf.| VI !!
PU5RXO | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
