[Qgis-user] CRS was undefined: defaulting to CRS EPSG:4326 - WGS 84
Patrick Dunford
enzedrailmaps at gmail.com
Wed Jul 18 21:41:15 PDT 2018
Raster files usually use additional files to define things like CRS. For
example, a .jpg raster file usually comes with up to three additional
files that define the CRS and the coordinates (.jgw, .xml and .aux.xml)
Generally I see this error when importing a raster that has one or more
of these files missing. The message then appears that the CRS has been
undefined and defaulting, and the coordinates for the imported layer
default to 0,0 in the defaulted CRS
Check if these files are present or if they are corrupted.
On 19/07/18 16:09, Andrew Davies wrote:
> I am in Tasmania, Australia which is CRS EPSG: 28355 - MDA94 / MGA
> Zone 55
> When opening a contour vector file which has been generated in the
> local CRS on Drone Deploy I am getting the following error:
> CRS was undefined: defaulting to CRS EPSG:4326 - WGS 84 I am running
> QGIS 2.18.21 Las Palmas which was working fine for a while. All I had
> done leading up to this error was open a raster DEM file and try to
> extract contours for the DEM. The extraction lagged out and I reset my
> laptop. I have deleted an Reinstalled with no luck. Kind regards. Andrew
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180719/8a5cf36f/attachment.html>
