[Qgis-user] Georeferenced raster images
Phil Wyatt phil at wyatt-family.com
Fri Jul 20 16:25:27 PDT 2018
Hi Wolstan,
If you are using QGIS3, head to the plugins and make sure the georeferencer plugin is ticked. It then becomes available in the raster menu. I suspect that is what you are looking for.
Cheers - Phil
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Wolstan H M Dixie
Sent: Saturday, 21 July 2018 8:50 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Georeferenced raster images
Hi - I am a new user struggling to pick up the fundamentals - I have
successfully imported a LIDAR raster layer and hillshaded / pseudo
coloured / contoured it.
My problem is that I want an image of a topographical map  behind it as
a base map to provide context.
The GIS I am familiar with had the facility to take an image eg TIFF,
JPG, PNG, georeference the four corners, and import it into a layer so
that it was matched to the vector map. This seems a simple and I should
have thought common requirement eg you want to put a TIFF of a historic
map behind the modern map you are creating.
I cannot see any way of doing it - am I being obtuse?
Any help appreciated
Wolstan
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
