[Qgis-user] Bug or Feature - QGIS 3.2 raster styling
    Shawn Carter
    shawn.m.carter at gmail.com
    Tue Jul 31 18:13:05 PDT 2018
Sure.  https://1drv.ms/f/s!AhIPPYddAyx1gdsPGUUrwQMwtCGqOA
In that web share folder you'll find a GeoTiff with values ranging from -1
to 1.  The second file is a style file with three classes.  If you remove
the middle class, my QGIS will quit displaying any values...add a third
class it works.
On Tue, Jul 31, 2018 at 4:31 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Wed, 1 Aug 2018 at 02:21, Shawn Carter <shawn.m.carter at gmail.com>
> wrote:
> > One of the more common tasks I use QGIS for is creating flood inundation
> and water extent maps using a variety of remotely sensed data.  My general
> method for visualizing the data was to create a discrete singlelayer
> pseudocolor ramp  with two classes.  For example, if using NDWI data I
> would set values of [-1, 0.1] as fully transparent and [0.1, 1] as opaque
> shade of blue.  On Ubuntu 18.04, QGIS 3.2 I've noticed that if I only use
> two classes, the data isn't displayed.  If I add a third class it will be
> displayed.  Is this a problem and should I submit a bug report?
> Could you share a sample dataset and project showing this issue?
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180731/16b0f011/attachment.html>
