[Qgis-user] Processing modeller window not functional
Howard Frederick
simbamangu at gmail.com
Wed Jun 6 05:59:52 PDT 2018
Works perfectly! Thank you.
On Wed, 6 Jun 2018 at 15:53, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hi,
> This issue has been reported already and it was fixed on QGIS master:
> https://issues.qgis.org/issues/16428
> There's a workaround for 3.0:
> - search and delete/rename the qgis_customwidgets.py file.
> Hope it helps
> Howard Frederick <simbamangu at gmail.com> escreveu no dia quarta, 6/06/2018
> às 13:22:
>> QGIS 3.0.3 / Ubuntu 16.04
>> Using "Create new model ..." in Processing gives an unusable window, with
>> the selectors for inputs and algorithms impossible to use (too small, and
>> cannot be resized - see screenshot below).
>> Is there a fix for this?
>> [image: image.png]
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180606/7a58789f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180606/7a58789f/attachment.png>
