[Qgis-user] Unable to load project
Springfield Harrison
stellargps at gmail.com
Sun Jun 10 23:30:03 PDT 2018
Hello All,
Thanks again for your insights, sorry for the delayed response. Very
helpful to get the different perspectives.
1. Yes, I understand the need for constant development and
improvements. And hence the need for some users to run multiple
installations for comparative purposes. I'm not in that league so
only need something that works reliably.
2. Again, I understand the benefits of using a Linix installation but
at this stage I'm not keen on managing more than one operating
system. In this realm, I would be considered an advanced amateur or
lower-level expert in computer management and GIS so taking on major
challenges is not something I would relish upon waking up each morning.
3. Thanks for some clarity on to installation processes. It would seem
that for the most utility, osgeo4w would be the preferred choice.
It turns out that I had installed 2.8.1 as a standalone and am now
running it successfully. It would seem unlikely that I should fall
back to 2.18?
4. Again, mixed signals here regarding versions, some advise 3.0,
others 2.18, while I am succesfully using 2.8.1. It would seem that
3.0 might be a good idea, would there be any obvious reason not to
migrate?
5. I see that Nicholas makes a good case for osgeo4w.
6. Good advice about backing up data, which I generally do but not
always as frequently as I should. I do appreciate learning
experiences but would prefer to choose those which are the more
satisfying. With my advancing years and very full days, I try to
pick experiences which advance my cause rather than just overcome
bugs. However, there is always value in learning.
7. Yes, I do appreciate the community support and find many problems
are also dealt with in the world of Google.
Thanks again, all thoughts are much appreciated…
Cheers . . . . . Spring Harrison
On 09-Jun-2018 05:31, Nicolas Cadieux wrote:
> Hi,
> Answers below
> Le 9 juin 2018 à 02:06, Springfield Harrison <stellargps at gmail.com
> <mailto:stellargps at gmail.com>> a écrit :
>> Hello Responders,
>> Thanks very much for your suggestions and comments. Very helpful.
>> I must say though that the last few comments have again underscored
>> my nervousness about changing anything that isn't completely broken.
> Ok but are having problems so things are broken.
>> Firstly, why are there two installation processes and what is the
>> purpose of each? This implies making a choice after learning about
>> the benefits and disadvantages of each. What are the criteria for
>> choosing one over the other? How long is the process of
>> understanding the options?
> There is the easy install and the OSGEO instal. The latest will give
> you more choices, like installing many versions or additional
> packages. You can also simply ask it to install all desktop package
> without having to ask yourself to many questions. The only
> disadvantage is that it does not really provide a good mechanism for
> uninstalling Qgis. You sometimes need to do it manually when things
> get complicated. That is my preferred install method. I think the
> easier Qgis install has a complete remove option usually found in windows.
>> Secondly, there seems to be no great consensus over the possibility
>> (or not) of conflicts between simultaneous installations. Again,
>> this makes me nervous.
> According to the Anita Grazer link I sent you, 2 and 3 store the
> settling and plugins in different places. Anita is my guru. If she
> said it was safe... it is safe! But I also tried it and what she said
> is correct. 2 and 3 live together and do not interact but yes, the
> problem is real in many cases, just not this time.
>> Thirdly, why are some operators running two or three simultaneous
>> installations? Does this mean that the latest version is not
>> adequate for some tasks?
> Some installs are for stable long term support (LTS). Some are
> under development (DEV). Qgis3,0 is what they call early adopters (so
> it is more likely to have bug but they have all the latest bling).
> The nightly builds are version containing the most resent fixes.
> Generally speaking, I go with the LTS at work and other versions at home.
>> All these things give me pause and discourage me from wading in to
>> something that may have a lengthy learning curve and an unpredictable
>> outcome. In this case, the devil you know definitely seems to be a
>> worthy rule of thumb. At least, until it fails utterly.
> Fix problems when you have time. Plan for extra time. Backup you data
> regularly so if shit hits the fan... you have a copy of all your
> files. This is just common good sense computer user practice.
> Consider the problems you create and solve as a learning experience
> and not an obstacle. Things get much less stressful if you know that
> you can only loose time and not your important data.
>> In that regard, I discovered that at some point I had installed 2.8.1
>> and, remarkably, it would load my ostensibly corrupt configuration
>> file. I appear to be back in business.
> Therefore your Qgis 2.10 is probably at fault and a update will more
> likely give you a more stable environment with better and newer
> features. Remember that opening a Qgis project from a higher version
> to a Lower version can lead to problems so make sure you add the Qgis
> version in the name of the file.
>> However, this version still bogs down upon loading the various layers
>> but does not fail after the delay. There are about 100 layers,
>> mostly vector.
> Things have probably improved since... that is why and upgrade is
> justified.
>> Anyway, not sure if this is particularly helpful but is my current
>> thinking on the upgrading process.
> Well we see that this is not easy for you. I sometimes feel the same
> sitting in front of a Mac where my reflexes are not as sharp as with
> windows. Again, do it if when you have the time, consider this as a
> learning experience and not an obstacle. Backup your data when doing
> something you are not sure of and use community support.
>> Thank you all again for your assistance…
>> On 08-Jun-2018 06:25, DelazJ wrote:
>>> Hi,
>>> Years that I'm using the osgeo4w installer (advanced install) with
>>> three concurrent releases minimum (ltr, current release, dev, and
>>> sometimes ltr-dev) and I can't recall on any issue I got due to this
>>> situation.
>>> And afaics there's nothing to be particularly careful of, it's just
>>> about click click click process and all got installed in the
>>> c:\osgeo4w64 folder.
>>> Just wanted to share my experience.
>>> Regards,
>>> Harrissou
>>> 2018-06-08 13:49 GMT+02:00 Philip Barlow
>>> <philipb at pembrokeshirecoast.org.uk
>>> <mailto:philipb at pembrokeshirecoast.org.uk>>:
>>> AFAIK if you install QGIS with the standalone installer that
>>> just puts the application and everything it needs into a folder
>>> in program files. You may encounter issues if you installed
>>> multiple versions with the osgeo4w installer if you aren’t careful.
>>> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
>>> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of
>>> *Patrick Dunford
>>> *Sent:* 08 June 2018 11:01
>>> *To:* qgis-user ML
>>> *Subject:* Re: [Qgis-user] Unable to load project
>>> That may be the case for the application. However, depending on
>>> the installation, shared libraries may be overwritten when a new
>>> installation is carried out and cause older software versions to
>>> stop working.
>>> On 08/06/18 20:11, Philip Barlow wrote:
>>> I am happily running 2.18.20, 3.0.3 and 3.1 (nightly builds)
>>> side by side on Windows 10. 2.x and 3.x store their user
>>> settings and plugins in different locations so there are no
>>> conflicts.
>>> Phil
>>> *Patrick Dunford
>>> *Sent:* 08 June 2018 05:02
>>> *To:* qgis-user ML
>>> The Windows version of Qgis allows you to run multiple
>>> versions on your computer side by side. I personally haven't
>>> used the Windows version for several years so I can't be
>>> sure if you will have any issues running 3.0 alongside your
>>> current version. I run many of the editions I have in
>>> virtual machines. If your PC has 8 GB or more of memory, or
>>> if you have access to another computer that can run Linux,
>>> then you can try it out in a Linux virtual machine or
>>> physical computer environment without disturbing your
>>> current installation.
>>> On 08/06/18 07:38, Springfield Harrison wrote:
>>> hello Patrick, thanks for your ideas. I will try the no
>>> plugins option.
>>> The program will run with no project loaded and it will
>>> run older project files but has problems with newer ones
>>> for the same project.
>>> I can load an older project file and then add newer
>>> layers to it and reconfigure them, Etc. This is very
>>> tedious but will amount to a recovery. It is better than
>>> starting from scratch for sure. But will the same
>>> problem reoccur?
>>> I have contemplated migrating to version 3 but I'm
>>> always leery of upgrades of anything as they often bring
>>> problems with them. In this list I notice many
>>> references to installation issues and things not
>>> running. 2.10 is a devil I know.
>>> can I expect any difficulties installing 3.0 +?
>>> Samsung Tab 4
>>> On Jun 7, 2018 1:30 AM, "Patrick Dunford"
>>> <enzedrailmaps at gmail.com
>>> <mailto:enzedrailmaps at gmail.com>> wrote:
>>> Thre are a number of troubleshooting steps to try out
>>> 1. Start up qgis using the -noplugins switch or remove
>>> all installed plugins or test removing one at a time.
>>> 2. Backup the config file and start with a new empty config.
>>> Qgis 2.10 is well out of support, is there any reason
>>> you can't migrate to 3.0?
>>> On 07/06/18 18:28, Springfield Harrison wrote:
>>> hello Phil,
>>> I did open the project file in Word, 2033 pages, and
>>> found 13 instances referring to the dxf file. Hard
>>> to say if anything was wrong there, nothing obvious.
>>> At least to me. Some other research I did indicates
>>> that maybe there is an authentication problem, not
>>> sure just what that boils down to.
>>> I don't think the dxf file is the problem. I renamed
>>> it and bypassed it on the startup routine which the
>>> program accepted but it still seized up with a
>>> spinning cursor. Some things still function, such as
>>> modifying the properties of a layer , Etc. But the
>>> screen is blank and nothing can be saved.
>>> For some time I have noticed that loading a project
>>> file bogs down for a while and then would resume to
>>> completion. Now it bogs down and blows up. The key
>>> message seems to be unknown exception.
>>> Some older project files do load successfully however...
>>> Samsung Tab 4
>>> On Jun 6, 2018 11:15 PM, "Phil Wyatt"
>>> <phil at wyatt-family.com
>>> <mailto:phil at wyatt-family.com>> wrote:
>>> Can you open a copy of the previous project file in
>>> something like notepad and see if anything obvious
>>> can be fixed and or removed in relation to the DXF
>>> layer?
>>> *From:*Qgis-user
>>> Behalf Of *Springfield Harrison
>>> *Sent:* Thursday, 7 June 2018 1:36 PM
>>> *To:* qgis-user at lists.osgeo.org
>>> <mailto:qgis-user at lists.osgeo.org> List
>>> *Subject:* [Qgis-user] Unable to load project
>>> Hello All,
>>> Bad News. I am unable to load a project that
>>> normally works with no problems:
>>> 1. QGIS 2.10.1, Windows 7.
>>> 2. Project starts to load, loads many layers . . .
>>> 3. halts loading "point Entity", a DXF file
>>> 4. the DXF file was renamed to trigger the Handle
>>> Bad Layers service
>>> 5. this was bypassed but project loading still
>>> fails to complete, cursor spinner on constantly
>>> 6. exiting with Save triggers "Unknown Exception"
>>> 7. the project file is trashed to 0kb
>>> 8. Exiting without Save is OK but no project can be
>>> loaded
>>> 9. Restoring previous project file versions yields
>>> the same results
>>> 10. Loading some other projects works but may have
>>> cursor spinner
>>> Any ideas what is going on here? I have rebooted
>>> the computer.
>>> Thanks very much . . . .
>>> Cheers . . . . . Springfield Harrison
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> List info:
>>> Unsubscribe:
>>> Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
>>> The Authority is happy to communicate in Welsh or English
>>> Website www.pembrokeshirecoast.org.uk
>>> <http://www.pembrokeshirecoast.org.uk>
>>> Follow us on Twitter <http://twitter.com/PembsCoast>
>>> Join us on Facebook
>>> <http://www.facebook.com/group.php?gid=26330984774&ref=ts>
>>> Watch us on Youtube
>>> <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
>>> Look at us on Flickr
>>> <http://www.flickr.com/photos/pembrokeshirecoast/>
>>> This email and any attached files should only be read by
>>> those persons to whom
>>> they are addressed and be used by them only for their
>>> intended purpose.
>>> If you are not the intended recipient please destroy all
>>> copies and inform the
>>> sender by return email.
>>> Please note that the contents of this email may be subject
>>> to public disclosure
>>> under the Freedom of Information Act 2000 and therefore the
>>> confidentiality of
>>> this message and any reply cannot be guaranteed.
>>> For further information on the PCNPA please visit our
>>> website at www.pembrokeshirecoast.org.uk
>>> Please consider the environment before printing this email.
>>> Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac
>>> unrhyw ffeiliau sydd
>>> ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio
>>> at y diben y bwriadwyd hwy.
>>> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech
>>> gystal � dinistrio pob copi a rhoi
>>> gwybod i'r anfonwr gyda throad yr e-bost.
>>> Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod
>>> cael ei ddatgelu i'r cyhoedd o
>>> dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu
>>> cyfrinachedd y neges hon
>>> nac unrhyw ateb.
>>> Am ragor o wybodaeth am APCAP ymwelwch �'n gwefan ar
>>> www.arfordirpenfro.org.uk <http://www.arfordirpenfro.org.uk>
>>> Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch
>>> yn dda.
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
>>> Virus-free. www.avg.com
>>> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180610/c43837d8/attachment.html>
