[Qgis-user] Export segment values in polyline in excel
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Jun 15 05:29:21 PDT 2018
Just use the field calculator to create a new column with the length.  Then you can save the file in csv and export it to Excel.
http://www.qgistutorials.com/en/docs/calculating_line_lengths.html
Nicolas
> Le 15 juin 2018 à 07:48, daniel pinto <daniel.ar.pinto at gmail.com> a écrit :
> Dear sirs i have an image with several polylines to measure the elements in need in said image.... i need to have the segments measure of each polyline exported to excel... thru the atribute table... is that possible???
> Thank you in advance!!
> daniel pinto
> arqueólogo
> 91 869 1397
> rua de Arouca, nº 10, 1º esq, 3810-050 - Aveiro
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180615/2e549026/attachment.html>
