[Qgis-user] WFS failure
Jeroen Hovens
mail at groenebij.nl
Fri Jun 15 08:20:48 PDT 2018
Thank you,
Setting it to 1.1 or 1.0 works. 2.0 and automatic gives the error.
@Philip Barlow, clearing the cache didn't help. And besides, my cahce-setting is 0 kb 😊
Greetings,
Jeroen
-----Oorspronkelijk bericht-----
Van: Even Rouault <even.rouault at spatialys.com>
Verzonden: vrijdag 15 juni 2018 16:44
Aan: qgis-user at lists.osgeo.org
CC: Jeroen Hovens <mail at groenebij.nl>; Qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] WFS failure
Jeroen,
It looks like this server doesn't properly implement WFS 2.0, and wrongly expects a TYPENAME parameter to be provided for the GetFeature request, whereas QGIS provides the TYPENAMES one as per the standard.
The solution is in the window defining the connexion parameters to force version 1.0 or 1.1, instead of letting the automatic version selection
Even
> Hi all,
> Using Qgis 2.18.20 (64bit, windows) I can't download/open a specific
> wfs layer. Using 2.14.18 (64bit, windows) the same WFS link works
> without a problem.
> What is going wrong in 2.18.20?
> The error is the following (in Dutch)
> Laag se:OGC_Gasnetbeheerdervlak: Downloaden van objecten voor laag
> se:OGC_Gasnetbeheerdervlak mislukt of gedeeltelijk mislukt: Server
> genereerde een uitzondering in het antwoord GetFeature: Internal
> error. U kunt met F5 proberen om de laag opnieuw te laden
> The wfs link is the following (all public data)
> https://ogc.polygonentool.nl/wfs?
> Username: MijnAansluitingOGC
> Password: MApoly2017
> Thanks in advance.
> Jeroen
> Qgis-user mailing list
Spatialys - Geospatial professional services http://www.spatialys.com
