[Qgis-user] Using qgis as realtime decision support tool
DelazJ
delazj at gmail.com
Tue Jun 19 07:08:12 PDT 2018
Actually the Join feature in 3.0 is documented [0] (I didn't check
yesterday but I should have remembered that the author of this feature
almost always provide documentation for "his" features).
And I think that a direct join with your Excel data is possible.
[0]
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#joins-properties
Regards,
H.
2018-06-19 0:59 GMT+02:00 DelazJ <delazj at gmail.com>:
> Hi Jeroen (and others)
> The add delimited text file tool [0] has a "watch file" option that, if
> i'm not mistaken, allows to apply in QGIS changes that would be made in the
> csv file in other applications such as MS Excel. So, assuming you have a
> table data with your municipalities and all the related information in
> csv-like format, you import it as simple table with the Add delimited text
> file, do a join with the spatial data and do a symbology on whether there's
> a project or no.
> Then what will be needed is simply update the csv in Excel and map is
> updated in QGIS.
> That's the theory as I could not run a 2.18 (I guess this is what you use)
> to check if it works. Doing it in 3.1 fails: I can see the change in the
> imported table but no repercution on the joined field nor the map (Bug?).
> However 3.x adds new and powerful (but not yet documented) features in the
> join table such as "Dynamic form" which perfectly triggers maps repaint
> when the csv is changed outside QGIS.
> If instead of csv, you want xls or xlsx there's a "spreadsheets" plugin
> that allows to esily use those formats in QGIS but I can't tell you if it
> has all the features.
> About the statistics, one can also use virtual layer [1] and do a query
> with aggregates. But having a Yes/No field in the table on which you
> perform stats should return what you are looking for I think.
> [0] https://docs.qgis.org/testing/en/docs/user_manual/managing_
> data_source/opening_data.html#importing-a-delimited-text-file
> [1] https://docs.qgis.org/testing/en/docs/user_manual/managing_
> data_source/create_layers.html#creating-virtual-layers
> Hope that heps,
> Harrissou
> 2018-06-18 22:29 GMT+02:00 Jeroen Hovens <mail at groenebij.nl>:
>> Re-opening the project does indeed update the map.
>> And the statistics toolbar does provide useful information, but just for
>> 1 column at a time.
>> Okay, learned some new things, but it is not yet the decision support
>> tool I am hoping to have 😊
>> For best results, this still needs me as a person to incorporate changes
>> as they are made/chosen or to manually update maps etc.
>> Maybe building a webmap and letting the group switch on and of proposals
>> (by (de)selecting them in the webmap legend) is still a fancier idea. This
>> however requires me to build a map with 60 layers, one for each proposal,
>> all uising the same basic nation-map and adding information to 1
>> municipality... That doesn’t sound effective. And then they still have to
>> make changes in two files, with consistency errors waiting to happen.
>> Any fresh ideas?
>> Is it possible to incorporate a map directly into MS excel? So the map
>> part is visual within Excel, maybe even without the use of qgis?
>> -----Oorspronkelijk bericht-----
>> Van: Raymond Nijssen <r.nijssen at terglobo.nl>
>> Verzonden: maandag 18 juni 2018 18:34
>> Aan: Jeroen Hovens <mail at groenebij.nl>; qgis-user at lists.osgeo.org
>> Onderwerp: Re: [Qgis-user] Using qgis as realtime decision support tool
>> On 18-06-18 17:10, Jeroen Hovens wrote:
>> > That would work if updating the xlsx file automatically leads to an
>> updated map. Does it, or do I have to renew the join every time the xlslx
>> is updated?
>> Just (re)opening the project should work. You can easily test it locally.
>> > I would like the decision makers to see directly what happens to the
>> geographical spread if they refuse proposal 10 to 21 (for instance based on
>> quality of the proposal). Because geographical spread is one of the
>> criteria and this is best visualized with a map (instead of a list of
>> municipality names), they can argue and reconsider choices. That's my need
>> for 'real-time'.
>> > Combined with the wish to make changes in just one document (xlsx being
>> the easiest) in stead of two (both xlsx and qgis), I am looking for
>> solution.
>> To be honest, opening the attribute table and edit some cells manually in
>> an edit session is not too complicated imho.
>> > I have to look into the Statistics panel. Will that provide cumulations
>> of a certain column based on a selection of fields (all the selected
>> proposals)? And what is used to create that selection? Does it refresh
>> automatically?
>> Yes, you choose the layer and column and it shows all statistics. It can
>> also show the statistics for the selected features only.
>> > Van: Qgis-user <qgis-user-bounces at lists.osgeo.org> Namens Raymond
>> Nijssen
>> > Verzonden: maandag 18 juni 2018 13:35
>> > Aan: qgis-user at lists.osgeo.org
>> > Hi Jeroen,
>> > If I understand you correctly, you just want to color entire
>> municipalities based on information in one or few columns? And the
>> challenge is cooperating with others, who don't know QGIS?
>> > You could use a shared drive, like dropbox, to store 3 files:
>> > 1 table (xlsx or csv)
>> > 1 geo layer with municipalities (gpkg or shp)
>> > 1 qgis project, with the table joined to the layer, and with the
>> desired style
>> > Others can update the table, and you (and others) can open the project
>> and see the updated map in qgis.
>> > Would that work?
>> > On 18-06-18 12:40, Alexandre Neto wrote:
>> >> I agree that one layer would be preferable. Using the categorized
>> >> renderer would make it easy to select and deselect proposals. You can
>> >> create the classes with a mix of the name of the munucipality and the
>> >> bugdet, that way that is visible directly on the legend, making it
>> >> easier to select.
>> >> Then you can use the Statistics panel to show the stats over a column,
>> >> for example the budget sum.
>> >> Jeroen Hovens <mail at groenebij.nl <mailto:mail at groenebij.nl>> escreveu
>> >> no dia segunda, 18/06/2018 Ã s 11:27:
>> >> I have not organized the data yet, that will depend on the pro’s
>> and
>> >> con’s of idea’s how to use it.____
>> >> __ __
>> >> For now, I am thinking along the following line:____
>> >> All municipalities as fields with attributes being whether or not
>> >> they have a proposal and specific information about the proposal
>> >> such as budget needed, type of project, etc.____
>> >> That would mean 1 layer with all the proposals. That way it seems
>> >> easier to show the entire map (all municipalities white, just
>> >> borders, and all municipalities with proposal coloured), so to
>> >> easily see the spread.____
>> >> __ __
>> >> __ __
>> >> *Van:* Alexandre Neto <senhor.neto at gmail.com
>> >> <mailto:senhor.neto at gmail.com>>
>> >> *Verzonden:* maandag 18 juni 2018 12:03
>> >> *Aan:* Jeroen Hovens <mail at groenebij.nl <mailto:mail at groenebij.nl
>> >> *CC:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org
>> >> *Onderwerp:* Re: [Qgis-user] Using qgis as realtime decision
>> support
>> >> tool____
>> >> __ __
>> >> Hi,____
>> >> It's not clear how your data is organized, making it dificult to
>> >> help in such a specific request. All the porposals are in the same
>> >> layer, or in diferent layers?____
>> >> __ __
>> >> Still, if you put all the proposal layers in mutually exclusive
>> >> group, it will be easy to swap between proposals.____
>> >> __ __
>> >> If they are all in the same layer, you can categorize and in the
>> >> legend you can select which proposal to show.____
>> >> __ __
>> >> https://docs.qgis.org/testing/en/docs/user_manual/introduction/general
>> >> _tools.html?highlight=mutually#interact-with-groups-and-layers____
>> >> __ __
>> >> You can also create an atlas with the necessary visualizations for
>> >> each proposal and the calculus of the values you wish to show. But
>> >> again, it all depends on how you have you data organized.____
>> >> __ __
>> >> __ __
>> >> escreveu no dia segunda, 18/06/2018 Ã s 10:19:____
>> >> Hello,____
>> >> ____
>> >> I am thinking about using qgis as a real-time decision support
>> >> tool and I am looking for some good ideas to ease the
>> >> process.____
>> >> ____
>> >> The case is the following:____
>> >> I have proposals from 60 municipalities (out of a possible few
>> >> hundred), each has 1 proposal. There is only room for 20
>> >> proposals to be accepted. One of the criteria will be the
>> >> geographical spread of the proposals: it is preferred to have
>> 20
>> >> proposals sort of evenly spread over the entire country,
>> instead
>> >> of having the majority of them coming from one region.____
>> >> ____
>> >> My idea is to show these proposals on a map by colouring the
>> >> municipalities. As a decision support tool I need the ability
>> to
>> >> adjust the selection in real-time (during the discussion). The
>> >> easy way is to just edit the attribute table or to select or
>> >> deselect specific municipalities. This however requires myself
>> >> to be present and make changes in qgis as the discussion goes
>> >> (given that nobody else in the decision group knows how to
>> work
>> >> with qgis).____
>> >> An alternative is to produce a webmap and have each
>> municipality
>> >> with a proposal have it’s own specific attribute value (but
>> all
>> >> using the same colour in categorized style), so they all show
>> up
>> >> in the map-legend, and any group member can easily select or
>> >> deselect a specific municipality from the legend.____
>> >> ____
>> >> Do you have other ideas how to use a map as a real-time
>> decision
>> >> support tool?____
>> >> ____
>> >> Quality of the proposal is the main criterium, but in addition
>> >> to the geographical spread there are others as well, such as
>> >> variety in projects and the cumulative budget for the selected
>> >> proposals (the cumulative budget is capped). Since I am not
>> well
>> >> known with database and calculation options in qgis and how to
>> >> automatically show the results, I am building an easy to use
>> >> excel file that will show all this information using precoded
>> >> calculations, much like a dashboard. Simply selecting and
>> >> deselecting proposals in an excel interface show you the
>> changes
>> >> in variety of projects and cumulative budget. This is much
>> >> easier for the decision team to do themselves, since MS Excel
>> is
>> >> a well known environment. ____
>> >> Ideally I get the two connected somehow, so selecting and
>> >> deselecting proposals will alter the results in both the map
>> as
>> >> in the excel dashboard. However, altering data in excel
>> doesn’t
>> >> automatically change the results in a qgis map, because they
>> are
>> >> not connected in real-time.____
>> >> ____
>> >> Do you have any ideas how to make a real-time connection
>> between
>> >> MS Excel and a qgis map? Or information on how to use qgis
>> >> internal capabilities to calculate certain values based on the
>> >> selection of proposals? However, the last option will probably
>> >> still need myself to be present to somehow select or deselect
>> >> the proposals in qgis.____
>> >> ____
>> >> Greetings,____
>> >> Jeroen____
>> >> ____
>> >> ____
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe:
>> >> https://lists.osgeo.org/mailman/listinfo/qgis-user____
>> >> -- ____
>> >> Alexandre Neto____
>> >> ---------------------____
>> >> @AlexNetoGeo____
>> >> http://sigsemgrilhetas.wordpress.com____
>> >> http://gisunchained.wordpress.com____
>> >> Alexandre Neto
>> >> @AlexNetoGeo
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Terglobo
>> > Fahrenheitstraat 1
>> > 5223 BJ 's-Hertogenbosch
>> > 06 25 31 49 83
>> Terglobo
>> Fahrenheitstraat 1
>> 06 25 31 49 83
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180619/56fc06c7/attachment.html>
