[Qgis-user] How can I display satellite images in hdf format in RGB color?
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Jun 24 07:55:25 PDT 2018
Try gdal_translate with the -sds switch. You find a GUI version in the raster menu or in processsing. That should split all your bands into individual single band tiff. Then you will need to figure out what band you want to display to make the rgb. Maybe the semi automatic classification plugin has an easier way of doing this.
Nicolas
http://semiautomaticclassificationmanual-v5.readthedocs.io/fr/latest/tutorial_1.html
http://www.gdal.org/gdal_translate.html
-sds:
Copy all subdatasets of this file to individual output files. Use with formats like HDF or OGDI that have subdatasets. The output file naming scheme has changed in GDAL 1.11 (e.g. ofile_1.tif, ofile_2.tif).
> Le 26 avr. 2018 à 00:43, Yoshie Ishii <18am401h at vc.ibaraki.ac.jp> a écrit :
> Hello everyone.
> I am using version 2.18.18.
> How can I load satellite images in hdf format and display them in RGB color?
> I tried to convert hdf format into tiff format, and then load satellite images as tiff format.
> But I would like to do that more easily.
> Kind regards.
> Yoshie Ishii
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180624/944bf3a8/attachment.html>
