[Qgis-user] Delete key does not remove item in composer
Alexandre Neto
senhor.neto at gmail.com
Wed Jun 27 02:08:21 PDT 2018
On Linux, version 3.2 works as expected, both DELETE and Backspace remove
layout composer items
Can you try to use a clean settings profile and check again?
DelazJ <delazj at gmail.com> escreveu no dia quarta, 27/06/2018 às 10:02:
> Hi,
> Let's not be so categorical and please, indicate also the platform you are
> working on. I've reported a bug long time ago (QGIS 2.8) about macOS
> https://issues.qgis.org/issues/12874
> Checking right now, I can say that:
> - on macOS, QGIS 2.18.0, both buttons do delete composer items
> - on Windows 10, using QGIS 2.18.21 and 3.3, both buttons do the same
> thing.
> Maybe, there are some local settings that interfere but on my side,
> documentation looks right.
> Regards,
> Harrissou
> 2018-06-27 10:30 GMT+02:00 Frank Broniewski <hallo at frankbroniewski.com>:
>> Hi,
>> I just want to confirm that DELETE never worked for me (can't recall it
>> ever did), BACKSPACE does though.
>> Frank
>> Dipl. Geogr. Frank Broniewski
>> Waldhölzbacher Str. 51
>> 66679 Losheim am See
>> 06872 509 068 4
>> 0176 611 26 9 2 6
>> www.frankbroniewski.com
>> -----Ursprüngliche Nachricht-----
>> Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von
>> Bernhard Ströbl
>> Gesendet: Mittwoch, 27. Juni 2018 10:25
>> An: Qgis-user at lists.osgeo.org
>> Betreff: [Qgis-user] Delete key does not remove item in composer
>> Hi all,
>> the documentation [1] states that for removing an item in composer one
>> can either use Backspace or Delete. However Delete does not work for me :-(
>> Is there anything I am missing?
>> Tried:
>> QGIS 2.18.20 on Win7 and Ubuntu 16.04, QGIS 3.2 on Ubuntu 16.04
>> [1]
>> https://docs.qgis.org/2.18/en/docs/user_manual/print_composer/overview_composer.html
>> Bernhard
>> __________ Information from ESET Mail Security, version of virus
>> signature database 17619 (20180627) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180627/d6ec2104/attachment.html>
